Higher than 319 boost limit
Old May 28, 2008 | 11:25 AM
turboracer's Avatar
I would like to use higher than 319 in my boost limit table. How hard would it be to come up with a patch or add to an already popular patch? (hint: the popular one has a 5 in it's name). I do not write code so please explain this to me in layman's terms.
Thanks
Old May 28, 2008 | 01:48 PM
bnice01's Avatar
set it to 319 thru out the whole rpm (thats the max it will go up to). Then set your Timer to 50000, that will basically disable it.
Old May 28, 2008 | 05:09 PM
tephra's Avatar
I have a solution, you will be able to double your max loads, I will post up for 88590015 when I get to work!
Old May 28, 2008 | 05:31 PM
bnice01's Avatar
I love it when you talk dirty like that tephra LOL
Old May 28, 2008 | 06:51 PM
tephra's Avatar
ok for 88590015 add
Code:
<table name="Boost Limit Dbl" category="Turbo" address="15cc4" type="1D" scaling="Hex16"/>
Now change the "Boost Limit Dbl" table from 0x6DDD to 0x4D00.
Also change your "LoadBoost" scaling from
Code:
<scaling name="LoadBoost" units="%" toexpr="x*5/4" frexpr="x*4/5" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="big"/>
to
Code:
<scaling name="LoadBoost" units="%" toexpr="x*10/4" frexpr="x*4/10" format="%.0f" min="0" max="638" inc="1" storagetype="uint8" endian="big"/>
Note the toexpr, frexpr and max changes.
Let me know how/if that works.
Cheers
D.
Old May 28, 2008 | 07:03 PM
tephra's Avatar
Just to be sure everyone understands the ABOVE mod is UNTESTED!
I guess do the mod and set your boost limit load to something like 120 and then do a low speed/low load logg to make sure you hit the limit like normal...
Old May 28, 2008 | 07:44 PM
JohnBradley's Avatar
I cant set it higher than 102 for some reason? Do I need to enter it as a hex value or something now?
Old May 28, 2008 | 08:40 PM
tephra's Avatar
scalings are around the wrong way...
max should be 319*2 ie 638
Old May 28, 2008 | 08:56 PM
maybe its cause I use 1.30
Old May 28, 2008 | 09:17 PM
tephra's Avatar
my bad scaling should be:
Code:
<scaling name="LoadBoost" units="%" toexpr="x*10/4" frexpr="x*4/10" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="big"/>
obviously for 1.30 and below it needs to be endian=little
Old Jun 6, 2008 | 12:31 PM
alan678's Avatar
any new word on this?
Old Jun 6, 2008 | 12:43 PM
cossie1's Avatar
same code for 90550001 ??
Old Jun 6, 2008 | 02:02 PM
BarryC's Avatar
HMMM could this be used to reduce the maximum timing retard limit???
at addresses 173f for 90550001 and 133f for rom 88570008
at the moment when its set to 255 the max limit is -10
could this get us down to -20 ???
ANTILAG
Old Jun 6, 2008 | 02:12 PM
cossie1's Avatar
Barry I think I fixed your table last night
richardjh
Nov 6, 2024 04:41 AM
richardjh
Jul 28, 2017 03:49 PM
EVO2003VIII
Feb 27, 2016 08:23 AM
butte
Nov 12, 2015 04:23 PM
