omni 4 bar setup?
Im in need of a little help guys, Setting up this Omni 4 bar on rom id 55570006 is kicking my butt! LOL I started with a tephra xmod rom for this 2010 X.
I installed the 4 bar map sensor and changed the settings under "Omni 4 bar boost" to the correct settings for Omni 4 bar. With the key on, engine off, im seeing -2.4 psi via evo scan mode23 logging. So my question is, did I setup the sensor correctly in the rom? Or is my evoscan logging incorrect? Thanks so much for the help guys! |
https://www.evolutionm.net/forums/evo-x-engine-management-tuning-forums/516456-omni-4bar-writeup.html
I read this thread, it doesn't have the coding I need for my rom id but has all the other info when changing map sensors. Thanks again. |
You should try RAX Patch v2 logging.
https://www.evolutionm.net/forums/ec...m-patches.html Once you figure that out, you can edit the MAP to adjust for the 4Bar MAP sensor right in EvoScan 2.9.xxx (newest version). Simply right click on MAP, edit, input new values. I like to also edit the notes to save 3Bar and 4Bar settings so I can just copy and paste. Omni4Bar MAP Sensor. Eval (PSIG) = [RAX_D_Dat]BITS(32,9)*0.11715 MetricEval (kPa) = [RAX_D_Dat]BITS(32,9)*0.8077214 |
2 Attachment(s)
Originally Posted by GSXRiderK6
(Post 11554561)
Thanks GSXRider! Im still confused in one area. Im following you on the logging part but not on the actual tune side. Do I not scale the 4 bar map sensor in the tune itself first? Or that's not needed?
Originally Posted by browningderek
(Post 11555331)
http://www.evoxforums.com/forums/sho...d.php?t=126938 http://ripnet.us/software/tuner-helper/ |
I need help figuring out why my evoscan is logging much higher boost than is actually there. I'm using Tephra V3 for my X with RAX. I've zeroed my WGDC/boost tables and my Zeitronix gauge, logged load, and perceived power (butt dyno) all agree that I'm at wastegate pressure of only 19ish PSI... but per below you can see that Evoscan is saying I'm at 32PSI. Please see below my screenshots, including my scaling for the boost. I've also included a screenshot of my ecuflash ROM showing I have it all enabled. Do I have to "scale" my MAP or something? I've only had this issue recently when I realized I had a bad boost leak... I fixed it and then had way high boost an so I zeroed out my WGDC/boost tables to start from scratch and I noticed this discrepancy. Any ideas?
https://cimg6.ibsrv.net/gimg/www.evo...ed24cb77eb.png https://cimg8.ibsrv.net/gimg/www.evo...38faae5586.png https://cimg4.ibsrv.net/gimg/www.evo...556ad73760.png |
Any specific reason you went with a 4bar sensor? Are you really wanting to read past 32psi?
https://www.evolutionm.net/forums/ev...r-writeup.html A summary: In standard EcuFlash definitions, you need to: - take the X-axis scale values from MAP based Load Calc #3 and paste them into #2 - take the X-axis scale values from Fuel Compensation MAT vs MAP - Omni4bar and paste them into - Stock3bar - revert 3x values under Omni 4 Bar Boost back to factory - if using PSI-based boost target, copy Boost Target 3x tables from Omni 4 Bar Boost section into Direct Boost section - also, copy OBTR Y-axis from and to the same - also, copy Target Boost Error Correction from and to the same |
Thank you so much! Yes, I run about 32psi right now, no idea what I did to screw this up when I went to V3... I do this so infrequently now that I find myself having to relearn all this. I have some questions:
https://cimg7.ibsrv.net/gimg/www.evo...b475361b82.png |
Hiya.
For Omni 4-bar logging in EvoScan using RAX Fast Logging, try revising the formula to... MAP imperial: [RAX_D_Dat]BITS(32,9)*0.11715 MAP metric is: [RAX_D_Dat]BITS(32,9)*0.8077214 Rich |
Originally Posted by richardjh
(Post 11872256)
Hiya.
For Omni 4-bar logging in EvoScan using RAX Fast Logging, try revising the formula to... MAP imperial: [RAX_D_Dat]BITS(32,9)*0.11715 MAP metric is: [RAX_D_Dat]BITS(32,9)*0.8077214 Rich I did go through and follow the directions in that link posted by METAL_AF and I'm still seeing basically pegged boost in evoscan (~32psi) but I know I'm only running about 19psi. |
Originally Posted by honki24
(Post 11872487)
Thanks for the input Rich! Indeed, that's the formulae I'm using per my screenshot above. Any other ideas?
I did go through and follow the directions in that link posted by METAL_AF and I'm still seeing basically pegged boost in evoscan (~32psi) but I know I'm only running about 19psi. Your EvoScan "RAX Fast Logging" Boost item should simply be as follows... [Map]-[Baro] ...whereas you have an actual calculation in there. So... Make sure your MAP is reading correctly. Make sure your Baro is reading correctly. Your "gauge" boost is simply one minus the other. :) Rich PS. It looks like you're also missing Boost Target as a logging item. See if you can get that one back, as it's useful! PPS. See if your logging works faster if you disable EvoScan's "multithreading" mode. Go to "Files" menu and TICK "Disable MultiThreading". |
Thank you so much!! I'll look into all of this!
1 Attachment(s)
(Post 11872770)
Okay, I see it.
PS. It looks like you're also missing Boost Target as a logging item. See if you can get that one back, as it's useful! I fell out of practice with this stuff and recently bumped up to Tephra V3 and have been having trouble since. I'd like to be fully TephraV3, RAX, and OMNI compliant. |
(Post 11872770)
Okay, I see it.
Your EvoScan "RAX Fast Logging" Boost item should simply be as follows... [Map]-[Baro] ...whereas you have an actual calculation in there. So... Make sure your MAP is reading correctly. Make sure your Baro is reading correctly. Your "gauge" boost is simply one minus the other. :) PPS. See if your logging works faster if you disable EvoScan's "multithreading" mode. Go to "Files" menu and TICK "Disable MultiThreading".
