Knock sensors and knock detection
I'd like to start a discussion on knock sensors and knock detection. I'm basically trying to tune a heavily modified 2.0l 4g63 and would like to be able to make some educated decisions as far as attenuating the knock filter maps.
What I've learned so far:
- Looks like the Evo knock sensor is a piezoelectric microphone
- Looks like the stock ECU knock filter maps use RPM and Load axis and are populated with Volts (presumably some kind of threshold for the 0-5 V signal from the knock sensor)
I've attached an Excel spreadsheet that contains the 12 knock filter maps from a stock 2003 ECU ROM, including a graph for each one.
What I'd like to determine:
- Why 12 knock filter maps? What condition(s) would determine the use of one map over another?
- What frequency is the stock knock sensor tuned to?
l8r)
l8r)
l8r)
l8r)
There are also various resonant modes the knocking can take on. This image shows most of the modes for a typical pent-roof combustion chamber:
Lots more information here: http://www.vehicular.isy.liu.se/Publ...PhD_580_LE.pdf
And here: http://www.vehicular.isy.liu.se/Publ...LIC_962_IA.pdf
(carefull look at the Yoshiyama-Tomita model, if Ion-current modelling is your bag)
Also, feel free to search the old NACA (aka NASA) archives for "engine knock" or "detonation" here: http://naca.larc.nasa.gov/
Lots of good documents there. TR912 is of particular interest. In either case, whole buttloads of good information on knock both in general and in specific. Lots of high-speed Schliren photography of knock, interesting conclusions and unusual methods. It's old, but interesting notwithstanding.
-Adrian
Live4Redline
Jul 17, 2024 07:09 AM
crcain
33
May 9, 2008 09:52 AM
