413whp 382wtrq so far...
mellon tuned my car a while ago. in december i added the buschur; cone filter (had stock intake with k&n panel filter), ss ported o2 housing and jet coated exhaust manifold.
after my first pull (with the initial rom he sent me) mellon ran it through the dll. the last figures he emailed me are stated in the title ( i dont have the graph for that) but below is the first pull i did with the first tune he sent me.
this is benchmarked against my final pull without the above additional mods last year. i am running 26psi now where before i was running 24psi but i think these are pretty good gains. we are still tuning and should be intersting what the final results are. i am running straight 93 pump. see current mod list in sig.
Very nice numbers..Maybe i missed it in the post..Was this on 93 pump gas..Im pushing for 400 hp myself..Im looking at the green next,and an o2 housing..I made 355hp and 344 tq..On TTP's dyno..Scott tuned it and i think he did a great job..Mine is on a evo 9..I was undecided on cams though..Maybe after i get the rest in,and if im still not satisfied..then i'll go with kelfords..Anyways,great numbers..Ive heard alot of good things about mellons tunes..Justin
thanks. yes it was on 93. mellon does an outstanding job.while i like the green turbo and it made sense for me because i had the smaller 8 turbo you may not see much of a gain between your stock 9 and the green. i bet an 02 housing ported stock exhaust manifold and cams would get you close to 400 on your stock turbo. if you do want to upgrade your turbo i would go with the red then you will be way over 400
looking good, I'm just perfecting the fuel and making sure it's rock solid at this point so the hp/tq may fluctuate up or down a little from here. It's definitely one of, if not, the strongest Evogreen cars I've tuned
[/IMG]
