Working on my race Evo on the dyno
Old Aug 8, 2009 | 07:39 PM
DynoFlash's Avatar
I am getting ready for the DSM Shootout in Ohio next weekend - trying to dial in my HTA88 Forced Performance turbo and Buschur short block
This was todays best run with .82 T4 bck housing
Nice and smooth broad power band and spools up well
Going to swap back housings and dyno again tomorrow - shooting for 800 whp
Al
Old Aug 8, 2009 | 08:02 PM
batty200's Avatar
What are the uncorrected and SAE #'s. Looks good. How much boost?
Old Aug 8, 2009 | 08:20 PM
DynoFlash's Avatar
This was at 43 psi
Did not look at it uncorrected - sorry
AL
Old Aug 8, 2009 | 08:38 PM
ineedspots's Avatar
chart looks good so far, good luck reaching your goal
Old Aug 8, 2009 | 09:36 PM
stikiller214's Avatar
dats a nice power band
Old Aug 8, 2009 | 09:49 PM
Joshs EVO's Avatar
Pretty good
Old Aug 9, 2009 | 07:59 AM
binh's Avatar
Saw you run at atco last tuesday. Car needs some traction off the line!
Old Aug 9, 2009 | 03:15 PM
DynoFlash's Avatar
I have been working today to change the turbine housing and discovered that one of the bolts which attach the back housing to the center had backed out and fallen off. Althoughits a direct passage to the inside of the turbine housing I am not sure if that one leak would explain all the power I am missing. Later I will go back and finish the job and get it back on the dyno. Al
Old Aug 9, 2009 | 10:04 PM
DynoFlash's Avatar
Well its been a long week of hard work and testing, wrenching and tuning. I am glad that I was able to get back the power i had before. It seems that many of the changes I made in the off season were steps backwards. This is where careful testing and keeping an open mind are important to veify what works and what does not work.
Tonight I had the car back on the dyno after changing the turbine housing back to the .68 T4 back housing and you can see that right off the bat with the same tune I picked up nice power in the low to mid range - with a bit of tuning I picked up even more power all through the power band
Thats all the time I can spend for Shootout prep this year - we'll see if I can crack a 9.6 - 9.7 with this Gt37 sized turbo and access the situation after this race.
Al
Old Aug 9, 2009 | 10:47 PM
xRoguex's Avatar
why remove the grodens?
Old Aug 10, 2009 | 06:32 AM
binh's Avatar
Yes, wondering the same thing.
Old Aug 10, 2009 | 06:41 AM
DynoFlash's Avatar
They are a year old
Al
Old Aug 10, 2009 | 06:48 AM
mike 99gsx's Avatar
Originally Posted by DynoFlash
I had a set fail in the past - also from what I have heard several others have had sets fail. As far as I can tell Groden sucks.
Al
Are you sure you aren't getting thread pull from retorquing them too many times? How many times had you had the set retorqued that failed on you? You can also request a better rod cap bolt than the normally supplied ARP.
Old Aug 10, 2009 | 07:35 AM
DynoFlash's Avatar
The set that failed on me broke in half at the top end of 4th gear
I thought it was a fluke until I learned of the same thing that happend to several others I know
I have never had a ARP rod bolt fail
Keep in mind I have a full ONE YEAR on these rods and feel they dont owe me anything. I just want them to get through one more race and then its time to toss them.
Al
Old Aug 10, 2009 | 08:22 AM
xRoguex's Avatar
Ill take your used and abused rods! ;-)
