HTA86, 2.1 liter, all BR parts.... big power on E85
No surprise since the car is all of the best parts available basically
Im really surprised tho the gains down low for only 100cc increase in displacement. I guess the increase in static compression and added timing from E85 help some what in the equation.
Id love to see this car in the 9.1Xs before the years over
Highly doubt it sees the track this year. Im going to try but i dont know if it will happen.
I had it out on the street tonight! FEELS AMAZIING!!! Just driving it drives like normal and smooth as butter. No more jerking at part throttle! And then I did a pull and second, well it ripped the tires loose and I was sideways!
F'ING NASTY!!!
F'ING NASTY!!!
Is the "before" plot done before they made that change to your dyno recently which shifted the power band sideways? And I can't remember which way it shifted the powerband. Right or left?
Also are you using the 64 or 63 block for your 2.1?
The before numbers were done after the dyno was coreected. They were over the summer for those numbers. The dyno was changed early in the spring if I remember correctly.
Its a 4g64 block.
Its a 4g64 block.
I dont want to comment for Dave, but we have found the old hotrod rule of thumb of 4% per full point of compression holds true. This isnt a stroker obviously, but the larger piston diameter builds more torque than a smaller bore.
Another BR E85 beast !!!! Great Job David and Brian.
That is a stout increase man and damn to move the curve that far to the left is plain nasty , I know it feels nasty on the street man be careful hahahaha!!!!
Brian what rpm are you hitting 20 psi curious as Dave likes to use 20 psi vs rpm to indicate spool characteristics. Just curious against mine ??
Thanks alot guys!
Car feels amazing! As long as the weather holds, it looks like Ill be at the track tomorrow! So there will be an update tomorrow night if that holds true!
Im not sure on the 20 psi off the top of my head. I dont have a boost gauge in the car and havent logged it on my computer yet to be able to check.
