Ported Manifold Dyno Comparison: Buschur vs MAP Rev2
Old Dec 8, 2009 | 11:57 AM
scheides's Avatar
EvoM Moderator
This is a re-post, just to get the original data back up here. The original thread was deleted because of all the dirt kickers and whiners. If you don't have anything CONSTRUCTIVE to add, please just DON'T BOTHER POSTING.
This is a dyno test comparing the Buschur Ported and ceramic coated stock exhaust manifold and MAP's Rev2 ported stock exhaust manifold.
1) Testing was performed on a Dynojet dynamometer with SAE correction and a smoothing value of 5.
2) Testing was performed in one dyno session over a matter of just a few hours yielding consistent intake air temperatures and negating any environmental factors. The car remained strapped to they dyno while the manifolds were swapped.
3) No changes to the tune were made during testing yielding consistent boost, timing, and AFR's.
4) Standard Buschur and MAP exhaust manifolds were used for this testing, no changes were made and no additional work was performed.
Actual data from actual comparo runs presented above:
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-mwiep.jpg
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-fq3if.jpg
Note that my boost numbers are slightly higher than MAP's, since we used different map sensors, and mine was not zero'd out before the test.
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-vlqvb.jpg
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-blqzh.jpg
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-8y8fj.jpg
Ported Manifold Dyno Comparison: Buschur vs MAP Rev2-zpajf.jpg
Depending on the run, you'll see that the buschur port job nearly equal but slightly out-done by the more extreme MAP port job, but is consistently bested by the MAP manifold above 7000rpm. On average, gains in the midrange were around 4-5whp and up top they were on average 8whp.
Full mod list:
Buschur Racing 3" TBE w/ bullet testpipe
Buschur Racing Intake w/Perrin filter
BR Race FMIC
Custom LICP
BR Upper IC Pipe
OEM IX BOV
AMS/TMS L19 headstuds
MAP Stage 3 Ported Head
Kelford 272 cams
GSC beehive valve springs
BR Ported/Coated Exhaust Mani
CBRD BBK turbo
MAP ported/coated turbine housing
BR SS O2 Housing
BR Ported Intake Manifold w/ EGR delete
BR 65MM TB
Walbro 255HP fuel pump
4x Kracka Vent setup w/ ebay catch-can
Buschur dipstick retention spring
Aquamist HFS-1 Alky Injection Kit (1.0 + .9mm jets)
FIC 1050cc injectors
GM BCS
Evo X MAP sensor
Innovative LC-1
GM IAT
Tephra v7t6 ROM w/EGT Elim, Direct boost mods
Again, if you don't have anything constructive to add, please just don't. These were results of my car, did as scientifically as I could, tried to keep as even as possible. I'm just one guy, with an evo, trying to make it the best it can be with what I have available. Thanks for reading.
Old Dec 8, 2009 | 11:59 AM
Kracka's Avatar
Thanks for posting, Scheides. This is definitely valuable information on ported exhaust manifolds. I was present for this testing and I can assure everyone that Scheides and MAP did everything possible to keep the test as fair as even as possible.
Old Dec 8, 2009 | 12:18 PM
Gary@MellonRacing's Avatar
nice results , thanks for taking the time to do the tests
Old Dec 8, 2009 | 02:43 PM
red03evo's Avatar
oh
Old Dec 8, 2009 | 04:58 PM
fqjdmct9a's Avatar
nice! thanks for the info!
Old Dec 8, 2009 | 05:54 PM
aka.ralliart15's Avatar
Nice gains, looks like the exhaust manifold can be ported a bit more it seems. look like its spooling a bit quicker too with the REV2, can anyone confirm? I can't really see much with all the colors.
Old Dec 8, 2009 | 06:00 PM
detroit pistins's Avatar
nicely done!
Old Dec 9, 2009 | 11:30 AM
RockmanX's Avatar
not this again.
Old Dec 9, 2009 | 01:29 PM
Saleentones's Avatar
Any idea what a stock manifold would have made?
Old Dec 10, 2009 | 06:40 AM
CleverUserName's Avatar
do you happen to have stock mani data on that car? if not, no biggie, i have seen the stock vs rev2/rev 3 data from map.
in any event, makes sense to get the map mani. thanks for posting the data!
Old Dec 10, 2009 | 06:56 AM
Murf's Avatar
^would also like to see a stock mani next to the two tested.
Old Dec 10, 2009 | 11:03 AM
darwin_evo's Avatar
Nice gains. On a more aggressive setup (ie: fp black) the gains would be even more!
Old Dec 10, 2009 | 11:22 AM
sLUg_'s Avatar
map ftw
Old Dec 10, 2009 | 12:16 PM
kouzman's Avatar
Nice test man!
Am i reading it corectly on the excel graphs? It seems that the Map manifold spikes just a tiny bit higher and it runs just a tiny bit leaner. Would this be the reason for the increased power?
Since the tune remained unchanged for both manifolds, what the higher boost and leaner afrs mean? Deeper porting? Larger porting?
Is it possible to have average hp from both manifolds? In other words what's the average hp difference let's say from 2500rpm to 7500rpm?
Old Dec 15, 2009 | 07:42 PM
fqjdmct9a's Avatar
+1
