More CBRD BBK XL tweaking
Yes. The spool is awesome and it puts a smile on my face as I'm in the early stages of a 2.3L build and I'll need a very suitable turbo. My only concern is what do you fellahs recommend as a minimum to strengthen the drivetrain as having that much torque could be an area worth addressing, right?
Bryan, Have you guys tried turning the boost up to 38+psi or is that over spinning the turbo by what Chad says? I'm interested to see what the specs of the compressor wheel and turbine wheel are in comparison to the Red and Black. I'm not sure that Chad would want any of that to be released yet or not. Great power band by the way. So you think that v7 with the larger maps really helped out? Would you happen to have the boost plots for v5 vs. v7? Sorry for all the questions Bryan...
*Edit - On a side note... The M2s are prob not helping the power band. With the built motor has your customer been interested in the FP5Rs or S3s since he doesn't have to worry about valve clearance? Even the S2s would help out a lot. Aaron did some testing between the S2s and M3 and he gained like 30hp I believe.
Great work Bryan
Mikey
Great work Bryan
Mikey
The V7 resolution difference has helped a ton with tuning timing. I find I can run more timing in different RPM areas then I could with the lower resolution because of the ability to fine tune the sensitive areas. This is even more apparent on pump gas 91.
I've noticed the evos love running the biggie maps if tuned correctly.
Yes I would imagine this car would make more power with a more aggressive cam but I believe the owner wants a nice tolerable street car.
- bryan
