High Boost & Stock Turbo - Boost Curves Please
Old Feb 22, 2010 | 12:47 PM
asubennett's Avatar
Lightbulb High Boost & Stock Turbo - Boost Curves Please
From what I can tell we have many of the following threads started already.
Stock turbo HP / TQ
Stock turbo E85 graphs
Stock turbo x y z here
But what is hit or miss between all of these threads is a boost curve to go along with the numbers.
So lets consolidate them into one thread here. Please post the following information only.
1. Stock Turbo ID (8 or 9) - (No FP color turbo allowed)
2. Stock block ID - (Yes or No) (If No ID built 2.0, 2.1, 2.2, 2.3)
3. Fuel Type (E85 or 93 or whatever)
4. Dyno Numbers (WHP & TQ) No Curve required
5. MOST IMPORTANT (Max Boost , Boost at Redline) Boost Graph preferred
6. SECOND MOST IMPORTANT - type of boost control being used
7. Type of 02 Housing
PURPOSE - I am curious to see who is having the most success holding boost. The ECU Controlled boost guys, the MBC controlled boost guys, the EBC controlled boost guys, the guys with external dumps, the guys with recirc O2 housings, the guys with 18 or 25 psi wga, or the guys with all of the above etc... You get the point.
Hopefully this thread turns into something worthwhile.
Old Feb 22, 2010 | 01:09 PM
BLKCarbonEVO's Avatar
1. Stock Turbo IX Ported
2. Stock block 4G63
3. Fuel: 91+100% Meth
4. 417hp/452tq
5. Spike 35psi holding 23psi at 7.5k (boost curve attached below).
6. Turbosmart MBC
7. Ported Megan
I think It would have held more out the top if I had my external dump on it and if I had an EBC. I recommend the AEM Tru Boost. That dyno had the 18psi wastegate. I had a 25psi wastegate but never tried it because the stock turbo blew up at 35psi. That's when I got the Red.
Old Feb 22, 2010 | 01:56 PM
asubennett's Avatar
That is some unreal TQ on a stock 9 turbo.
Perfect example of a post to by the way. Hope we can fill a few pages with the same type of post. Then I will pivot table the data to see if we can come up with some sort of trend to analyze.
Old Feb 22, 2010 | 02:19 PM
I just happen to do trend analysis for a living.
Mikey
Old Feb 22, 2010 | 04:10 PM
l2r99gst's Avatar
1. 2005 Evo 8 stock turbo
2. Stock block/head/IM/exhaust manifold
3. E85
4. 400/400 (conservative tune by me - 0-16*)
5. Max boost - 32psi Boost at redline - 22psi (23 cutout closed)
6. Profec Type S EBC
7. Stock O2 housing
As an fyi, what you trying to find out isn't going to amount to much. Anyone maxing out the stock turbo is going to be in the same ballpark on max boost at redline, just varying by a few psi depending on the mass airflow that the particular setup can flow.
For example, higher VE setups will max out the compressor at a lower boost level than a lower VE setup...ie larger cams can flow the same mass airflow at a lower boost pressure than stock cams. It has nothing to do with being able to hold boost when the compressor is already maxed. Intake temperatures will also come into play.
What you are trying to figure out would work on a bigger turbo that isn't being maxed out. Then the various parts come into play.
Old Feb 22, 2010 | 07:09 PM
JohnBradley's Avatar
AEM BCS, Ported Megan O2
and to support Eric-
Buschur Racing MBC, QTP
Both cars very similar mods but the obvious differences are 2.0 vs a 2.4, both are SD, both are 10:1 compression+, Luke has a Magnus and Jake has an extremely ported stocker. Both ran IX turbos with Lukes being aggressively ported both compressor and hotside and Jake only being light porting on the hotside.
Old Feb 22, 2010 | 10:11 PM
sparky's Avatar
Wow, Mikey, you got considerably higher torque numbers with the stock IX turbo than you did with the Red turbo. Neat!
Old Feb 22, 2010 | 10:13 PM
Ya but I was also running 35psi through a turbo that was made for low to mid 20s... If I ran 35psi through the Red I think I would be about 470tq.
Mikey
Old Feb 22, 2010 | 10:25 PM
at 30 you did 448 peak torque
Old Feb 22, 2010 | 10:31 PM
438tq at 30psi Aaron. You are talking about my Red right?
Mikey
Old Feb 23, 2010 | 08:15 AM
4th gear we got it to spike a little higher, but it was still 30ish.
Old Feb 23, 2010 | 09:34 AM
I didn't remember the 4th gear pull numbers, I just knew it didn't make more power...
Mikey
Old Feb 23, 2010 | 10:26 AM
JesseB's Avatar
Sorry to go off topic but asubennett, same person that used to have white all motor eg in AZ?
Old Feb 23, 2010 | 10:46 AM
asubennett's Avatar
Wow, that is random but yes. Was promoted and transferred from Phoenix back in 2005. Have been in Chicago since. Is this Jesse who used to work at PeakBoost / then did AFI? Tyring to connect the dots.
Old Feb 23, 2010 | 01:08 PM
JesseB's Avatar
Yes it is...I remember Anthony telling me back then you were moving...anyways good to see you on here!
