Mikey's FP Black *** WOW ***
I don't know all the details on the cams but I believe they can be made for a 4G63, but not with stock clearance. I also know...that I want a set! Aaron, I'll send an email to figger some stuff out!
Congrats again, Mikey and Aaron! I would have loved to see Aaron's surprise on the baseline comparo run!
i have a buschur stage 3 head. i know im losing power with kelfords.
^I'm not positive as I'm not familiar with Buschur's staged heads. If it has similar or the same clearance as stock then I don't think so.
FWIW - Mikey only went down to ER today and clicked on kill mode because my wife's 2009 HONda Pilot smoked his *** getting on the freeway last night! HAHAHA!
He said he wanted 700, i wouldnt be surprised if he makes like 720 with his setup if its making what it is now at just 25-26psi.
Nice #'s and even nicer looking graph! Congrats! Looking forward to see what it can do on *kill mode*...
over 100 hp... from cams??? what??? fkn bad a$$!!!
Im officially jealous....
Awesome build!!!
Awesome build!!! good stuff man. I cant forget the most important mod though..... Aaron. LOL. his tuning looks ****ing DEAD on.
so between the cams + dump + magnus + SD probably like 120-130whp? this is the name of the game, have the best mods and you will extract abnormal power compared to other peoples setups.
are you gonna run out of fuel with 1450's or no?
No, it doesn't look like I'm going to run out of fuel. I should be able to get up to 725+ no problem, well fuel wise at least!
I pretty much have a "Large Housing" Black going on the car very soon
Pics and specs should be out soon and testing hopefully will be over the next two weeks.
The cams can only go into a build head... I would recommend Kiggly Springs! The other thing, these cams have a 12/11.7mm lift and can never be put into a stock block. You have to make sure you have custom piston that have large enough valve pockets to except the high lift cam
Thanks buddy!
Lets not forget the magnum! Thanks Erik. There is still more to go. Not where the car should be yet. I'll leave that up to Aaron!
Mikey
