First tune for my IX
I did a lot of research on this.... English racing has a good explanation:
http://englishracing.net/tech/2009/1...e-bench-racing
If I were in "ideal" conditions, my car would have put the same thing down, or close. Elevation and temp. are both big factors. I was a mile in the air and it was 101 degrees that day.
"Why I feel like this system for comparing dyno # can be wrong at times. I find that Correction factors are the more wrong on turbo cars. "
"When you are at high elevations you can run more boost and timing on the same oct fuel with out Detonation. I see lots of guys in the Colorado area that make 50-100hp off correction factor."
"If you are bragging high hp # that are alot higher due to Correction, does the car even have enough fuel injector, fuel pump, ignition, strong enough hard parts to make this power for real uncorrected? "
"Correction Factors may work right on a stock all motor car, But a highly modified car they are just fake # that mean nothing."
Also, the SAE says that any correction factor more then +/- .03 is inaccurate and should not be used.
Im not trying to hate or discourage, just trying to help educate.
Not discouraged at all. Don't know a lot about dynos and how they work. So you think my car without a correction factor at sea level would do 285 true hp? High temps and high altitude make for lower numbers is all I'm saying. I don't take any comments as hating.
I appreciate the feedback.
FS[Northeast]: PA Evo 9 Partout!!! <!><!><!>
projektevo9
For Sale - Part Outs
55
Aug 14, 2018 03:24 PM
FS[MidWest]: Evolution IX MR SE - Low miles
apexnine
For Sale - Cars For Sale
Jul 13, 2015 07:12 PM
