Evo IX/BR 2.0/FP Black/E85
Old Jul 31, 2010 | 08:17 PM
awddyno's Avatar
Woooooaaaaaaaaaaaahhhh.
Cant wait til I make the switch. Congrats. Low low 10s at least.
Old Aug 1, 2010 | 06:10 AM
Eric06's Avatar
It definitely pulls hard; takes off like a rocket. I've only had one chance to run it at the track since the build was done and that was before E85; which at that time, i was dyno'd at 541/460. I spun through 2nd gear on street tires and started to wheel hop, which separated the front drive axle from the trans. I took it up to BR to have it fixed and then switched to the ID injectors and E85. I am trying to work a set of wheels/slicks now so i can put the power down to the ground. It's def got low 10 sec capability if not high 9's. I'm also working on lightening it up a bit. Once i get the wheels/tires, i'll head to the track for a few runs...until i get kicked out that is...NO CAGE! lol
Old Aug 1, 2010 | 06:31 AM
MN_Evolution's Avatar
Very awesome, my set up is almost identical.
Old Aug 1, 2010 | 06:39 AM
EVO8LTW's Avatar
Wow...wish I had E85 close by. I have a very similar build. BTW, your link doesn't work.
Old Aug 1, 2010 | 06:42 AM
BLKCarbonEVO's Avatar
Looks sick! What cams do you have?
Mikey
Old Aug 1, 2010 | 07:36 AM
Eric06's Avatar
I've got the Cosworth M2 cams. I'll try to fix the link.
Old Aug 1, 2010 | 07:49 AM
17579EVO9MR's Avatar
Good numbers man. I cant wait for my 2.3 fp black build
Old Aug 2, 2010 | 05:09 AM
It is about time to upgrade the cams! I think a set of S3s would be amazing in your setup
Mikey
Old Aug 2, 2010 | 09:14 AM
murlo26's Avatar
x2
I want to run 40psi on mine, but I don't think Shane likes that idea since MN is E70 most of the year...not sure what he told you though.
Awesome numbers OP, gives me hope for my 2.0 Black build !
Old Aug 2, 2010 | 10:46 AM
Eric06's Avatar
I'll probably stay with the cams until David hammers out a BR IX grind.
psphinx81
Aug 30, 2011 11:37 AM
tscompusa2
May 2, 2011 04:42 AM
David Buschur
Mar 25, 2011 01:58 PM
David Buschur
Jul 12, 2010 04:14 PM
StreetThisEvo
Aug 4, 2009 12:04 PM
