518whp / 509wtq - CBRD BBK-B
Old Oct 18, 2010 | 09:23 AM
  #31
evodood's Avatar
Originally Posted by TK40
Chad I need to see a Full versus B overlay. You said only 200rpm spool loss?
I'll see if I can find my BBK Full dyno chart and post up some Excel graphs tonight.
Originally Posted by FQ4OO
very impressive!
What throttle body?
Mil.Spec
Old Oct 18, 2010 | 09:47 AM
  #32
RunThat's Avatar
Ordering mine too!
Old Oct 18, 2010 | 10:58 AM
  #33
scheides's Avatar
EvoM Moderator
Legit! I wish I still had my evo8...
Old Oct 18, 2010 | 12:25 PM
  #34
McLaren F1 2003's Avatar
Originally Posted by BEISSEN
No all the shops seem to think everyone has E85 readily available so its pointless with these dyno charts. A 91/92 dyno letting more power be had with say 93 and E85 would be better.
and most shops also think everyone has 93 readily available..which isnt the case either
good job as always gst
Old Oct 18, 2010 | 06:23 PM
  #35
evodood's Avatar
Heres the quicky Excel overlay. It's a little rough cause I had to try and figure out all the data points manually off the dyno charts but it should be close enough to give everyone a good idea between BBK Full and BBK-B
Old Oct 20, 2010 | 07:20 PM
  #36
XcreatonX's Avatar
Is this maxed out of the turbo. 34 psi? or do you think it has more left in it?
Old Oct 21, 2010 | 08:38 AM
  #37
evodood's Avatar
Chad said it could take it as high as 35psi but my boost gauge only goes to 35psi so....there'd be no good way to have a warning at that point. Im not too concerned about anything I may be missing staying just under the recommended limit.
More important for my setup right now, I think I need to focus on other effeciency mods and this turbo will shine more. Intake mani. perhaps a different cam profile, etc.
Old Oct 22, 2010 | 10:55 AM
  #38
RunThat's Avatar
what was the base WGA spring pressure before you turned up the boost?
Old Oct 22, 2010 | 03:05 PM
  #39
evodood's Avatar
No clue I never tried to run it at wastegate pressure. Chad will probably have to answer that.
Old Nov 19, 2010 | 04:46 PM
  #40
wally7714's Avatar
Originally Posted by CBRD
awesome numbers Bryan! I'm glad you were able to finally tune our production version after a very anticipated release!
On our Mustang Dyno we were more than happy with the BBK-B results after the time we spent developing it. After achieving 457whp on a stock block pump gas car I was excited to emphasize the old phrase "good things come to those who wait".
There are some nice options in the stock housing market now, I think this slots in as another great solution for our clientel!
cheers
cb
Hey Chad. How would you compare BBK Full and BBK B if it comes to spool and constraction of both. In the market for one
Old Nov 26, 2010 | 01:11 PM
  #41
dan08's Avatar
nice numbers.
Old Nov 26, 2010 | 03:56 PM
  #42
deebo3726's Avatar
any pumpgas numbers on this car yet?
Old Nov 26, 2010 | 08:04 PM
  #43
grahamab's Avatar
E85 is pump gas (at least where he is). besides, I'm pretty sure he only runs E85.
Old Dec 23, 2010 | 08:47 AM
  #44
kidtsi's Avatar
nice!
Old Mar 19, 2011 | 10:37 PM
  #45
EGbeater's Avatar
Sorry for the thread resurrection, but I'd like to know what the compression ratio was on this 2.3L build... I went to the GST website, but didn't see a 2.3L stroker motor listed... just two Cosworth engines:
http://www.gstmotorsports.com/store/...=69_78_117_646
Thanks in advance!
Originally Posted by GST Motorsports
This car was one of the testers for the beta BBK-XL. I've posted a couple threads about it before on here.
Now it has the final production version of the BBK-XL, the BBK-B.
2006 Evo GSR
Modifications:
GST 2.3L stroker
Oversized valves in head (no head porting)
3" Downpipe
3" Agency Power catback
RRE rally cat (resonated test pipe)
Titek V2 tubular 02 housing
Ported stock exhaust manifold
CBRD BBK-B turbo
GST open cone air filter
Perrin FMIC
AMS LICP
Synapse BOV
Cosworth M2 mivec cams
FIC "BlueMax" 1550cc injectors
AEM fuel Rail
AMS fuel return line
Denso IKH24 spark plugs (1 heat range colder)
BlaqOps Progressive double pumper system
GM 3 port boost solenoid using ECU-controlled boost
Stock ECU (Tephra V7 ROM)
Stock MAF
Stock Intake Manifold
Stock Upper IC pipes
E85
33-34psi peak, 30psi out the top
518 whp / 509 wtq in 4th gear
510 whp / 464 wtq in 3rd gear
- Bryan
