Near bone stock evo 8
Well, here ya go
Ya guys done made me angry
I put all of my effort into this tune since the disbelief of the tune and car. I'm pretty sure this is one of those "freak" evo's running around out there. I've only seen one other evo that was capable of taking to this tune with no knock.
Let me be very specific with everything since there were so many disbelievers...
Mods:
MAP O2 eliminator DP heat wrapped
ETS air intake/pipe
Ultimate Racing test pipe
Works custom exhaust...no resonator or muffler
Walbro 255 fuel pump
Grimmspeed 3 port boost solenoid
Omni 4 bar map sensor
Works DV
Stock IC, IC plumbing, long block, turbo, IM, Tbody, and exhaust manifold... Ie, NEAR BONE STOCK EVO 8
I have the proper weight of passengers this time and all that jazz for the corrected dyno....not that it matters
Once again, I implemented V7, gear based boost control, etc.
This pull and the other pull were done on Exxon 93oct. I turned up the boost a few psi to really prove a point, because I knew there was more in this car.
Enjoy the crappy cell phone pics of this beautiful car, dyno graphs, and logs.
Mods:
ETS air intake/pipe
Works DV
Edit... accidentally posted the uncorrected twice.
Here's the corrected.. By the way, notice I trimmed the RPM short on the chart even though the pull went longer than that
If a cop pulled you over in CA, you'd be getting tickets.
The bone stock reference was in regards to the MANY other simple upgrades that are possible.
Half the mods are for reliability and tuning. Exhaust and intake for what it's worth... That's pretty close to stock IMO.
EDIT:
Also notice if you could the difference in the first graph posted and and the final result. The smoothness of the power delivery now is perfect and there are no dead spots at all. I hope the owner of the vehicle chimes in to attest to the "reliable winter tune" to the "now I'm angry and I'll show you" tune. Yes, the car has a very nice assortment of parts, but..... there has to be somebody to extract the power from the thing....
I'm almost feeling the need for a famous Rodney Dangerfield quote here....
Still waiting for the skeptics to chime in here.
EDIT:
WOW!! My new tune is AWESOME !
lan_evo_mr9 - Thanks
for the AWESOME tune!! I just can't say enough about how smooth the car runs throughout the entire RPM range and it pulls hard!
One mod you may have forgotten to list is the AEM wideband, which should be obvious to many as it's required to collect the Air/fuel ratio data.
All I can say is the next time you post a graph with my data I sure hope other members here doubt you because your "I'll show you" tune is sick!!
for the AWESOME tune!! I just can't say enough about how smooth the car runs throughout the entire RPM range and it pulls hard!One mod you may have forgotten to list is the AEM wideband, which should be obvious to many as it's required to collect the Air/fuel ratio data.
I'm sure I would get lots of tickets in CA with this set up!! Fortunately, it's not my daily driver, just a weekend car that only comes out under the cover of darkness.
Maybe if I became a sponsor it would help my credibility?
Sorry for the words...gotta few beers in me at this point.
im sorry man... but i just got tuned by jestr a couple of days ago... and my car is a 03gsr with the 9.8housing... ain't NO WAY ur getting past 300whp (safely on 93) without upgrading ur factory fuel pump... and with just intk/exhst at 21-22psi on 93oct its near impossible to pass even 260whp... it took me 27psi to hit 295whp on 93oct... and i have the same mods as u... with the exception of L/UICP
OP, good job with the tune. Glad to see the owner is enjoying the car!
mantosride
Dec 27, 2009 10:48 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
PERRIN_Jeff
67
Jun 25, 2008 08:33 PM
