How much power can a evo 8 turbo make?
Old Jan 10, 2011 | 10:30 PM
  #31
03whitegsr's Avatar
Post a picture of this"EVO VIII" turbo. If it is ball bearing, it's not a EVO turbo at all. Up until recently, the only ball bearing stock frame turbo has been a custom piece done by Owens Development out of the UK.
While you are at it, maybe snap a picture of the injectors. If they are stock, then I wouldn't believe much over 400 WHP even with 65 psi base pressure.
Old Jan 11, 2011 | 07:12 PM
  #32
turncoat's Avatar
Originally Posted by tscompusa
what made you buy one? you got your *** wooped by one on the road?
i bet you already love AWD.
Actually I drove this one, it would do a couple little things my mustang wouldn't, you know, like go around a corner, and stop, and the power wasn't bad either considering the turbo was putting so much oil out it would kill every mosquito for miles around. What really done me in was the price, a little over three years ago I gave $12,500. 31500mi now it has 33225, unlike the guy before me I think I'd sell my wife first. You were right about the dyno maps if using VD you need to look through the data make sure it doesn't go down in rpms than back up. if it does anywhere cut it right there. after I did that to all my loggs the best I could get was 404hp 406 tq I'm going to post it with the AFR's 'cause I seen someone said he was sure you could get much over 400hp even with elevated fuel pressure and uhhhhhh...he's right. Of course you all know. AWD!, by the way as soon as I get a reasonable day. that dip in power at 5000 will be gone
Old Jan 11, 2011 | 07:55 PM
  #33
turncoat's Avatar
It looks like any other evo 8 turbo the reason I mentioned it was because it was just something I'd remembered from way back when I first bought the car and had the turbo done. I knew zip about evo's then. the odds are about 100,000 to one it is not, and they were just smoking me because they wanted more money /excuse for taking so long. My last post I put the best VD dyno graph I had with no rpm drops.( drops are prob missfires from being so lean, VD seems to read them and make the horsepower go up instead of down like a real dyno would). Put the Afr's in 404hp the next .02 sec rpm dropped(missfire from being lean 12.4 ^) On a real dyno hp prob would have fell like a stone.
Old Jan 11, 2011 | 08:02 PM
  #34
REV.olution's Avatar
pic of turbo or car?
Old Jan 11, 2011 | 08:19 PM
  #35
turncoat's Avatar
Originally Posted by Turbojunkie
10.90 damn, is your car full weight? I feel like asking 20 questions here 'cause I fully intend to make some passes in mine when I get it all straght. like 60 foot? 1/8 mile? Because most of the tracks close to me are, and I'll prob do most of my test and tune in the 1/8th. Tires? it sucks to be a newbie.
Old Jan 12, 2011 | 08:18 AM
  #36
Turbojunkie's Avatar
Thank you. 10s on stocker is a biotch to do. Yes, its a full weight RS. no jack and spare tire is all. I have quit a bit done to achieve my level of power tho. 9.5:1 comp ER built mtr, E-85 and 30+ psi spike. cams, fmic, ect ect. Ask away, that what the forums are for man
Old Jan 12, 2011 | 09:37 AM
  #37
tscompusa2's Avatar
was it a stroker turbojunkie?
Old Jan 12, 2011 | 11:05 AM
  #38
Nope. 2.0 build. Custom coated pistons. high compresion. standard Eagle rods.
Old Jan 12, 2011 | 11:33 AM
  #39
JohnBradley's Avatar
Billy has the quietest built motor I have ever seen....especially after 2 years of hammering on it. It wasnt until Jake's 2.4 that we had another one that was so quiet it uses 100% stock knock control.
aaron
Old Jan 12, 2011 | 04:08 PM
  #40
tscompusa2's Avatar
aaron
damn! Kreionics car was really quiet compared to my car (noise wise) when he had it idling.. his engine sounded so much smoother.
Old Jan 12, 2011 | 07:19 PM
  #41
turncoat's Avatar
sure no problem
Attached Thumbnails How much power can a evo 8 turbo make?-pic1.jpg   How much power can a evo 8 turbo make?-pic.2.jpg
Old Jan 12, 2011 | 09:16 PM
  #42
Boosted Tuning's Avatar
Can we get some pics of the turbo? Just for fun?
Old Jan 13, 2011 | 02:02 PM
  #43
turncoat's Avatar
the only pics I have off the car are the port work I done, I'll post those too, but not for awhile (don't want to give up any secrets just yet). Even though my first Dyno graphs were flawed, (thanks for letting me know tscompusa, made me go back and look through the data to see what caused it) as english racing says 380hp is about the max for stock injectors which I reckon is at stock fuel pressure. I can't keep my afr's below 12 @ 5600rpm, or about 4300rpm at max boost, that little turbo has alot left in it, I'm sure of it.
Old Jan 17, 2011 | 08:24 PM
  #44
Nismo2evoawd's Avatar
when i bought my car I called up cft omar and thats who tuned it and i didnt it believe him but maybe at one put my evo 8 built head, evo 9 turbo/ aem ems ect made the 400hp spiking 30psi he said when it was there.
INTERESTING THREAD
Old Jul 4, 2011 | 08:19 PM
  #45
analogEvo's Avatar
This thread is awesome lol I just had my car tuned on a dyno dynamics and made 317whp mind you this was his first Evo 8 he tuned.stock turbo,stock injectors,ams upper and lower icp,aps ic,aps bov,Megan 02,megan manifold,Megan tbe,hks 272 cams.94oct (not as good as USA 93) I'm sure I could make more power but I want to get a different turbo anyways.you can see the Evo 8 turbo fall on it's face in high rpms
