Spoolin up COP before/after VD results
Old Jan 27, 2011 | 08:48 AM
4xforce's Avatar
Originally Posted by Ian0611
Nice gains! Guess I need to move this higher up on my future mod list
Word!!! I really like his stealth kit. Fits nicely under the stock or similar spark plug/coil cover.
Old Jan 27, 2011 | 02:12 PM
eTiLiKo's Avatar
The COP kit is for sure a great kit, BUT if one of your pull need smooth 10 you cannot use it for a comparison.
Old Jan 27, 2011 | 05:06 PM
denile's Avatar
I added the same pulls with smoothing of 1.
Old Jan 28, 2011 | 08:51 AM
ROGERV's Avatar
Great Results, I just installed this same setup (used spoolinup cop) and car feels much smoother. I do feel a hp gain on the butt dyno... I reused my old spark plugs just opened up the gap to .028 from .022 and I have no blowout.
Old Jan 31, 2011 | 03:18 AM
Diddy69Art's Avatar
can't go wrong with matt's spoolinup cop kit !!!
i purchased a set with new coils, and also the high z injector resistor bypass, great products and awsome work from matt...
-Diddy-
Old Jan 31, 2011 | 07:13 AM
achilles3000's Avatar
When I had the stock coils car felt more rough revving threw the rpms after the cop from the butt dyno I even told matt i gained 10 whp or more best mod for the money.
Old Jan 31, 2011 | 12:48 PM
eTiLiKo's Avatar
Did you use RPM 2byte? Did you use the same piece of asphalt to do the pulls? Dyno sheets coming from datalog aren't so precise, if you want a barely acceptable result in terms of accuracy you have to be very meticulous.
Old Jan 31, 2011 | 01:25 PM
Dan0805's Avatar
Quick question. So If I just installed a COP tomorrow would my tune need to be re-adjusted?
Old Jan 31, 2011 | 01:38 PM
stryfetew's Avatar
Was it back to back runs? Regardless I've heard nothing but good things about his kits and have full intentions of purchasing a used setup with my tax monies
Old Jan 31, 2011 | 01:46 PM
turbotboz's Avatar
Cough Cough* Group buy/new thread?
Old Jan 31, 2011 | 01:55 PM
Dan0805's Avatar
Im down if someone will tell me if my current tune will have to be adjusted.
Old Jan 31, 2011 | 02:12 PM
turbotboz's Avatar
I would not think so. It should not effect Air/fuel ratio or timing. In my eyes it provides a "cleaner" route for the spark to reach its destination. Then again, I'm not a ecu "tuner."
Travis
Old Jan 31, 2011 | 02:16 PM
stryfetew's Avatar
I agree.. I would venture to say it's the same as changing oil, plugs, new gas etc.. Something that you wouldn't think would effect tune. Plug gap and all would remain the same as well.
Old Jan 31, 2011 | 02:23 PM
SPANKED's Avatar
I want one!
Old Jan 31, 2011 | 04:40 PM
PalmbergEVO's Avatar
How long did it take to install? Been considering doing this and now that I see these results you inspired me.
