Boostin Performance + SD + Evo 9 + 93 oct & E85
Old Mar 6, 2011 | 09:21 AM
Boostin Perform's Avatar
Boostin Performance + SD + Evo 9 + 93 oct & E85 = Awesome!
As some of you may know, my name is Devin Schultz (DevinTuned). I’ve been involved with the EvoM community for many years now and have recently opened my own shop called Boostin Performance.
Check out are grand opening announcement post!
https://www.evolutionm.net/forums/mi...ck-us-out.html
This is a Evo 9 I recently tuned on Speed Density. I was very happy with our results on pump gas (93oct) so I thought I would share them with you guys. I noticed a dramatic improvement in drivability. There are no hesitations when you lift off the throttle like on a maf car. When the BOV releases it’s the same, nice and smooth.
Mods:
  • 3" Turbo Trix intake with Vibrant air filter
  • AMS intercooler and piping, Tial Q BOV
  • Invidia O2 housing and full 3" exhaust
  • Turbosmart Manual boost controller
  • Omni 4 bar map sensor
  • 255 Fuel Pump, still on the stock injectors (130% duty cycle)
  • Stock Evo 9 Turbo
  • Stock Evo 9 Mivec cams
I would like to thank all the stock ecu gurus that made this possible! Tephra your donation is waiting for you. I've got some FIC 1150's, so when I get some time at the shop, I'm going to install the FIC injectors and retune the car. Ill post my results soon, and 400+ whp should not be a problem on E85!
Devin Schultz @ Boostin Performance
Old Mar 6, 2011 | 04:47 PM
marrrk's Avatar
very nice results, losing the the maf and going SD seems to really smooth things out. can't wait to see my car on this VD!
i wanna 10sec pass on 93?
Old Mar 6, 2011 | 07:22 PM
Cali 18's Avatar
really good numbers! I would love to see the injectors in there and the boost cranked up, running e85.
GOOD JOB!
Old Mar 6, 2011 | 07:30 PM
lude2evo's Avatar
does this have the 3250 throttle blip or any idle issues?
Old Mar 6, 2011 | 09:07 PM
No worries mark. We are going 10s on 93 all day long!
You might have to take it easy on the AWD burnouts. I got your clutch out today; its seen better days. Oh well, rebuild it and light em up!!
GOOD JOB!
Me too. I would like a mid to bottom 11 second pass on the stock tubo and cams!
No sir, it runs clean and smooth. Since the car has been tuned, the outside temps have dropped into the single digits. It started right up every time no matter how cold it was. No issues at all. It runs perfect!
Devin
Old Mar 7, 2011 | 04:30 AM
jtinautogear's Avatar
Wow, I am impressed with the numbers on stock injectors
Old Mar 8, 2011 | 11:44 AM
Ya I was suprized it made that power on the stockers.
The car was tappering a little leaner then I would have liked at redline. So for now I backed it down to 24 psi until we get the FIC 1150's in it.
Devin
Old Mar 8, 2011 | 12:09 PM
bimmer8181's Avatar
The stock injectors must be close to 100% duty cycle.
Old Mar 8, 2011 | 10:06 PM
According to evoscan they were at 130% duty cycle. I’ve noticed you really don’t run out of fuel with the stock ecu until about 120% injector duty cycle.
With AEM this seems to be the other way around, 90-95% injector duty cycle and you’re out of fuel.
Devin
Old Mar 9, 2011 | 01:22 AM
kiley_sean's Avatar
Looks real good, man.
Old Mar 9, 2011 | 10:20 AM
RSMike's Avatar
stock injectors with stock fuel pressure on the dynapak dyno run out (actually run lean) at 260kwatw(350whp), we had to drop it back to 240kwatw (320whp) to get a flat AFR reading
Old Mar 10, 2011 | 09:28 PM
Kiley sean, thanks
That sounds about right.
Devin
Old Mar 31, 2011 | 03:05 PM
The plan is to get this car out to the track this weekend and see what she can do.
We'll post up results as soon as we have them.
Devin
Old Apr 2, 2011 | 10:52 AM
BOOSTED_H22A's Avatar
^I look forward to seeing the results. The graph looks great, nice work.
Old Apr 4, 2011 | 05:33 PM
forc3 f3d's Avatar
was the turbo ported on the hot side at all?
