Evo9 2.3L GT35-82R and pump
Old May 19, 2011 | 08:57 AM
wirx's Avatar
This car is mostly for street and sometime for tracking
470whp / 428 ft-lbs @ 23PSI with pump and this -
GT3582R turbo http://www.atpturbo.com/mm5/merchant.mv ... _Code=VEVO
2.3L Stroker Kit http://www.vividracing.com/catalog/s...7-p-16133.html
ATS triple carbonetic clutch http://www.z1auto.com/prodmore.asp?m...ine&prodid=670
Modified exhaust
Cone filter
Magnus Intake Manifold
Agency Power High Flow Fuel Rail
Walbro 255L/HR Fuel Pump
Greddy Profec B Spec II Boost Controller
Kelford Hydraulic Camshaft Set 272 272
PTE 880cc Injector
Stock ECU
98E (same as US 93)
Fuel-air ratio 11.5
dyno graph (dynocom dyno it's quite conservative)
But because it's EU, here is US graph
http://www.youtube.com/watch?v=4--Yuxd0rio
Dyno mechanic refuses to add more boost and I was quite happy with result, but is it safe to add more with 93?
Old May 25, 2011 | 03:43 PM
wirx's Avatar
is it safe to add more boos with 93?
Old May 27, 2011 | 06:08 AM
EVO(boss)'s Avatar
nice car man ,,,,,
Old May 27, 2011 | 06:10 AM
High_PSI's Avatar
I was never a fan of the ATP kits, did they fix their issues? I remember that they had a LOT of lag and never made the power they should.
Old May 27, 2011 | 08:23 AM
wirx's Avatar
Actually i want Black turbo, but sadly nobody sells it, I got only time updates like next week, next month etc.
But lag is mybe only little bit more than stock, very little.
Old May 27, 2011 | 08:37 AM
High_PSI's Avatar
Well a 2.3 would help a lot along with the fact that it is twin scroll. Internally gated too, weird 35R setup. I am not sure about these new kits but the old ones stunk.
Old May 27, 2011 | 08:50 AM
Mauricio Evo IV's Avatar
Yeah, I think but maybe 2 or 4 psi more... Put methanol and boost to 30 psi
Old May 27, 2011 | 09:06 AM
andrewzaragoza's Avatar
a good tuner should be able to safely tune your car with more boost on a 35r. nice numbers btw.
Old May 27, 2011 | 09:27 AM
testa corse's Avatar
good numbers at only 1.6bar i like the torque numbers especially.enjoy
Old May 27, 2011 | 09:59 AM
EvoJoeIX's Avatar
your probably gonna need bigger injectors to go higher on boost
Old May 30, 2011 | 03:11 AM
evo4nr's Avatar
Have run 36psi on 98E / 93US
Old May 30, 2011 | 10:15 AM
red03evo's Avatar
Truelly will need some bigger injectors for more boost probably. Any clue what your idc% is right now?
Old Jun 3, 2011 | 12:11 PM
wirx's Avatar
But with 1000 or 1200 injectors is more boost ok?
Old Jun 3, 2011 | 02:37 PM
BillSpec's Avatar
1000cc and 28 psi on 93.
For higher boost, 116 octane, maybe 36psi. Should do good.
Why does the video say 585whp?
Old Jun 7, 2011 | 10:05 PM
REV.olution's Avatar
I have this turbo setup. What limited me the most was my 02 setup. I got a Map 02 delete pipe with external wastegate and dump. I'm spooling a whole lot faster, and it doesn't even feel like the same car. Check the sig for mods. Dyno updated soon.
