Andrew's Old School FP Green on E85
Old Sep 30, 2011 | 03:51 PM
Spec-Ops1's Avatar
Andrew has been a customer of ours for a while now and previosuly had a 93oct tune. He just returned from an underway period on a Sub, and while he was away they opened up an E85 pump a few blocks from his base, so he made the switch to the juice!
EVO VIII
MODS
Cossie M2s
Injen upper and lower IC piping
Injen Intake
Apexi MAF adapter and Filter
Metal IX Diverter Valve
AMS 3.5 Intercooler
Manual Boost Controller
Megan O2 Housing
3" Turbo Back Exhaust
GT Spec Tubular Manifold
FIC 1150cc (Low-Z) injectors
Single Walbro 255
This was at 29psi tapering to 22psi. I was wanting to turn the boost up a tad, but he was happy with where the car was at so we left it!
Thanks again Andrew, even though we always seem to have some sort of issue with the car, it always turns out great!
**UPDATE**
Andrew swapped out the Apexi intake for a Vibrant MAF adapter and Amsoil Air Filter, here are the results with 1 more PSI of boost... yeah not a true back to back, but I will bet money the Amsoil filter outflows the Apexi!
Here is the Comparison
Old Oct 1, 2011 | 11:27 AM
04EBevo's Avatar
Thank you freddie! The car feels great!
Old Oct 2, 2011 | 05:03 PM
zeus1's Avatar
congrats and thanks for your service!
Old Oct 3, 2011 | 06:47 AM
Levar's Avatar
Veteran: Army
I am a bit unsure as I thought the FP Green on E85 pushing 29PSI would be somewhere a tad higher. What it something with running out of fuel?
Old Oct 3, 2011 | 07:57 AM
Spec-Ops1's Avatar
Nope, remember, this not the newer HTA green... this is the old green that is a touch better than a stock 9 turbo...
Old Oct 3, 2011 | 08:17 AM
Levar's Avatar
Veteran: Army
OK. Thank you for the clarification, my friend. By the way, what is the most that you would personally spend on a used old FP Green?
Old Oct 3, 2011 | 08:26 AM
evo8426's Avatar
Though you're not asking me, I wouldn't buy a used one. Chances of it failing are pretty high being an older used turbo. I would feel much better about spending a little bit more for a better performing new turbo.
Old Oct 3, 2011 | 08:51 AM
Spec-Ops1's Avatar
All depends on the condition etc... I would definitely have to be in the market for one, and it would be purchased in person since they are getting to be older these days... honestly though, I probably wouldn't even look at the old school green these days...
Old Oct 3, 2011 | 05:33 PM
04EBevo's Avatar
Thank you! Yes this is the older green and there is quite a difference between this and the hta. I was not running out of fuel but we left the boost on the conservative side. I may go up in the future but am very happy with the power. It isnt really about numbers for me and freddie knows that. I want a car I can beat on and not worry about it breaking. Thats what I got!
Old Oct 3, 2011 | 05:35 PM
04EBevo's Avatar
If paying straight up, I would spend about 750-1000 depending on a condition. I would only do this if you have an evo 8 turbo because from a nine turbo it wont be a huge upgrade.
Old Oct 3, 2011 | 05:37 PM
goad_white03's Avatar
Looks good andrew!! Cant wait to see out comparison from your OLD Green and my IX Turbo on E85
Old Oct 3, 2011 | 06:35 PM
zeus1's Avatar
well enjoy the car. i ran the old green turbo from 2007 until the spring when the turbo housing clamp that holds the hot and cold sides together let go (the nut rusted off and the turbo split).make sure you check yours or as a precaution replace it. i loved that turbo.
http://store.forcedperformance.net/m...Category_Code=
Old Oct 3, 2011 | 08:34 PM
06evol's Avatar
Nice!!!
Old Oct 4, 2011 | 04:10 AM
Levar's Avatar
Veteran: Army
Thank you for the quick reply. This really helps me out.
Old Oct 4, 2011 | 09:30 AM
MRlong's Avatar
Good job Freddie! And Andrew, we'll have to get together some time so i can feel the new power! Definitly looking foward to my future tune by Freddie now...
