IX GSC S2 Cams, Stock Turbo
Old Mar 3, 2012 | 08:13 AM
  #31
Thrilla's Avatar
Veteran: Army
Goucho, thanks for the post. It got me thinking about S2s as well. If the street manners of the S2s are close to stock, then I'm sold.
Old May 1, 2012 | 03:50 PM
  #32
goucho's Avatar
Originally Posted by runningonE
I'm still debating if I should go with the S1's or S2's...my only concern would be daily driving with S2's... any feedback you can give on this goucho or anyone else with S2's. My plans are for a FP Green maybe FP Red later down the road.
For sure go with the S2's if you are upgrading your turbo. The S1's are best for a stock turbo, but really the S2's are the better Cam.
As far as daily driving, the S2's are a pretty mild cam. No rough idling or loupy feeling. However there is the "Cam Creep" or whatever it's called when your under 2k RPM in low gears. The Cam wants to GO, even if you don't want to. It's kinda like it's accelerating or decelerating, one or the other, not maintaining. Combine that with the Exedy Twin clutch and it get's annoying sometimes in stop and go traffic. Honestly it's not bad and definitely tolerable, but that is the only downside.
Old May 1, 2012 | 03:52 PM
  #33
goucho's Avatar
If you're ever interested in going for a ride to see the street manners, hit me up.
Old May 1, 2012 | 10:26 PM
  #34
Wirk's Avatar
Great product. We sell these all the time!
Old May 6, 2012 | 10:56 PM
  #35
ROUND3's Avatar
What about goin with Speed Density? Full intercooler setup instead of just lower pipe (which I believe is what you posted)...
Old May 6, 2012 | 11:37 PM
  #36
dastallion951's Avatar
s2's are driveable for dd. Mine gets driven everyday, another thing I noticed a big difference, with the s2 cam swap over my og hks 272 cams, same thing harder pull to redline, but then again on my setup when they went in a map rev 2 intake mani and milspec tb went in. Think about it most of us want an eventual goal of 400-500 realistically for a DD. These cams should never bottleneck around that power level. Id say personally enjoy the car for a while, then swap your turbo an 02 housing and ported exhaust manifold when you really wanna step up the power. Make power but keep it stealthy. haha
Good job ER
Old May 7, 2012 | 12:22 AM
  #37
Zerofour1223's Avatar
As far as daily driving, the S2's are a pretty mild cam. No rough idling or loupy feeling. However there is the "Cam Creep" or whatever it's called when your around 2k RPM in low gears. The Cam wants to GO, even if you don't want to. It's kinda like it's accelerating or decelerating, one or the other, not maintaining. Combine that with the Exedy Twin clutch and it get's annoying sometimes in stop and go traffic. Honestly it's not bad and definitely tolerable, but that is the only downside.
congrats on some nice numbers I was debating between S1's and S2's and this review has certainly helped thanks!
Old May 7, 2012 | 09:05 AM
  #38
goucho's Avatar
You're the second person to mention Speed Density. I need to look into that more. Would I be using the same stock intake tubing and cone filter? I've hesitated changing the intake because the just seem to make the turbo louder without really any HP gain. I'll check into the SD.
Also, I do have Intercooler as well as the LICP.
Old Oct 2, 2014 | 08:26 PM
  #39
D1andonlyantman's Avatar
Hi. Old thread and I'm not sure if you guys even post anymore but i figure it's worth a go I've got an evo IX with the usual bolt ons and decided to buy some cams before remap. One things led to another and I'm now getting forged rods, the head skimmed, better headgasket, stronger headstuds and some s2 cams fitted. I know the s2s are recommended for a larger turbo but will they be more suited for my setup than the s1's would have because I'm going to be running around 28psi because of the rods, or would I have been better off with the s1's? It's very possible I might upgrade the turbo etc at some point so i guess going with them was a good idea, but it would be nice to know anyway
Thanks
Old Oct 2, 2014 | 08:48 PM
  #40
goucho's Avatar
I'm not a tuner or expert knowledge, but from what I've read the S2's are the way to go, even on a stock turbo. The S1's are made for the stock turbo, but are a much milder cam. They will produce less power but may be a little better for streetability (stop and go traffic specifically). But if you're going to go to the extent of putting cams in, might as well step it up a level so you don't have to worry about it again. Especially if you're running 28psi, you're going to need a cam to flow all of that air. I have a feeling though you're stock turbo will be running out of steam to compress that much air.
Just remember to replace your springs, seats and retainers (grab the Beehive set from GSC). Also make sure you have a good tuner to properly take advantage of these cams. I promise you won't be disappointed.
Reviving this thread is giving me the itch to modify again. Not good because it's either a new turbo or full suspension. And I was considering selling too... Damn you.
Old Oct 3, 2014 | 02:22 AM
  #41
Yeah I bought the spring and retainer kit and I'm confident the evo is in good hands all this extra work was very unexpected. it went from just fitting the cams and EBC followed by a remap to tearing the engine apart because of my car doing pretty **** poor on a leakdown test, and seeing as he had to take the engine to bits to sort the valves and pistons it seemed stupid not to upgrade some parts while he was in there.... I've said this quite a few times since I bought the evo, "nothing's ever simple...." Sometimes you've just got to go with it I guess
Old Jan 25, 2016 | 08:39 PM
  #42
Ians06's Avatar
Another revival! Really good read goucho. Also love watching Aarons posts and info! Beautiful car. Did you sell the car?
Old Jan 27, 2016 | 11:43 AM
  #43
goucho's Avatar
Thanks for the compliments! It's nice to see people still getting information from this thread.
Unfortunately, I sold the car. It was a hard decision, but I couldn't justify it anymore with a growing family and me never driving it. I do miss it though. The guy I sold it to had some good plans for it, but I don't think he is active on this forum so I don't know what kind of condition it's in now (Terry, are you there?).
CrAnSwIcK
29
Aug 23, 2017 02:47 PM
ak47po
Nov 15, 2016 04:58 AM
Michael Cain
Nov 12, 2016 10:20 AM
Thrilla
For Sale - Cars For Sale
15
Jul 1, 2016 06:58 AM
JohnBradley
Evo X Dyno Results
19
Feb 27, 2016 08:03 AM
