Evo 8 Built 2.0L 6262 E85 40psi - 747whp
Old Aug 24, 2012 | 03:26 PM
tscompusa's Avatar
Originally Posted by brotus
What exactly were the fuel issues you were running into?
around 7k it was trying to go past 12.5 AFR.. i dont want it hitting 13 afr. basically it kept going leaner the higher you rev'ed once we upped boost.
Old Aug 24, 2012 | 03:36 PM
TurboTravis's Avatar
Tom, lay this over my 40psi and post it if you can. I think people would like to see that.
Old Aug 24, 2012 | 04:40 PM
tscompusa's Avatar
Good idea Travis. I will do that and will dig up this other 6262 also on 2.4. I will do it later tonight. yours will be a cool comparison since both are 2.0L
Old Aug 24, 2012 | 05:03 PM
evilempire76's Avatar
Wow what a beast! That things is make crazy power. Can't wait to see the final numbers.
Old Aug 25, 2012 | 12:44 AM
tscompusa's Avatar
Here is TurboTravis's car vs this car in this thread overlay
1byte RPM only allows for 7968.75 past that you must use 2byte RPM.
The only car i used 2byte RPM in the graphs is Travis's. I wouldnt be surprised if the 6262 is making past 747 based on this curve overlay.
pretty crazy though how identical Travis's HTA86 2.0L is to this guys 6262 2.0L
Old Aug 26, 2012 | 08:44 AM
Steven's Avatar
That's interesting, I would not have expected them to be so similar.
Old Aug 26, 2012 | 04:56 PM
4G63 DSM's Avatar
I wish I had E85!
Old Aug 26, 2012 | 06:32 PM
tscompusa's Avatar
same here.. the 6262 must be almost a clone of the 3586R. either that or shearers hot parts are magical.
Old Aug 26, 2012 | 06:53 PM
jmcmill3's Avatar
i want
Old Aug 27, 2012 | 12:36 AM
I'll re-VD my car one of these days. Little did we know that it had a ton of boost leaks between the TB and cylinder head at the time of the tune.
Old Aug 27, 2012 | 06:01 PM
gpfury86's Avatar
What are the engine internals? Whats the compression ratio? Just curious on how other setups were spooling compared to mine.
Old Aug 27, 2012 | 09:22 PM
MrLith's Avatar
The HTA86 is near 40whp more for near 2000rpm, I'd not call them that similar...
Old Aug 28, 2012 | 01:14 PM
awd2gen's Avatar
looking into a few things for my fuel issue..wondering if anyone has found the limit of double pumper(walbros) on e85?
Old Aug 28, 2012 | 03:22 PM
tscompusa's Avatar
i believe you can take a double pumper setup into the 950whp territory with the proper size fuel lines (which you have) on e85. (3/8" = 850whp dynojet).
to me it looks like the FPR isnt doing its job.. the afr will just keep climbing the higher you rev. maybe we should put the car on a dyno if you have one locally.
Old Aug 29, 2012 | 05:26 AM
CO_CReX's Avatar
Holy crap!! Awesome numbers! I bet it's super fun
