HTA Green SD 462 and 409 on Pump gas
Old Nov 29, 2012 | 02:27 PM
HIS Motorsports's Avatar
Originally Posted by ETS Michael
Great Job Guys!!
Thanks Micheal!
Old Nov 29, 2012 | 02:38 PM
jaysonsyl's Avatar
Does SD make that much of a difference with the green I'm about to get my tuned but still on maf
Old Nov 29, 2012 | 02:49 PM
It did on this car and most cars that I have switched to SD has picked up around 20 or more horsepower!
Old Nov 30, 2012 | 10:51 AM
vtec lolz's Avatar
Wow that's good power!!
Old Nov 30, 2012 | 12:18 PM
Blue91lx's Avatar
Would you say that these are normal pump gas results for the mods?
Old Nov 30, 2012 | 02:23 PM
kevin8086's Avatar
+1
I'm looking at an hta green and didn't know this was possible on pump safely
Old Nov 30, 2012 | 02:46 PM
It was very safe! I do believe the stock rod will take a beating for a little while if drove correctly. But you never know! It could break tomorrow.
Old Nov 30, 2012 | 03:00 PM
kevin8086's Avatar
Lol. I just didn't know that green would "safely" put down that much on pump on stock 2.0.
Maybe I should buy one or have my 9 turbo built to hta green if that's what is probable
Old Nov 30, 2012 | 03:02 PM
Blue91lx's Avatar
I know of ONE other car that made similar numbers on a stock 2.0L/Green.
I'm not doubting the numbers at all, I just want to know if I can expect similar numbers on pump.
Old Nov 30, 2012 | 03:15 PM
If the mods are close it should make close to the same numbers depending on the tuner!
Old Nov 30, 2012 | 03:35 PM
evo8426's Avatar
I know I have said I would never change from stock turbo unless I went to a built motor but this car makes me seriously consider going Green but also run with e85 when the local station hasn't run out
Old Nov 30, 2012 | 06:20 PM
kevin8086's Avatar
Damn. Now I really want a green
Old Dec 1, 2012 | 11:02 AM
Blue91lx's Avatar
Good to know. My setup is quite a bit more aggressive so I'm wondering if anyone has ever reached 500whp on pump with a Green.
2.4L, S3s, bowls blended, CB IM, etc.
Old Dec 1, 2012 | 01:36 PM
I would say it would be closer with a 2.4, but I would say the turbo will run out of breath before 500 on pump! Not E85 or a race gas should def. get it over 500!
Old Dec 1, 2012 | 01:37 PM
That does suck! But the green is awesome for spool and power!
