BrowningDerek Tuned Evo9 RS BBK Full
Old Mar 2, 2013 | 08:08 PM
  #31
RussellDaniel's Avatar
s3s are gonna make it shiiiine up top
Old Mar 3, 2013 | 03:44 PM
  #32
browningderek's Avatar
IMO with stock block having a few "topend" mods like s3's or a magnus intake is a good thing for overall power band and engine safety. His car hit 25psi @ 3550rpm BTW! Its a fast spooler for sure.
Old Mar 4, 2013 | 09:46 PM
  #33
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by evo8426
Post the log in the actual virtual dyno. Evoscans version inflates the numbers much more than virtual dyno. My guess is this is going to show sub 400whp. I can take a log that shows 550whp in Evoscan and put it into Virtual dyno and it will show 500whp with the same settings.
Also, you need to post multiple runs showing similar power numbers if you want to claim numbers.
i looked at the log from the night we tuned it. the actual log from the graph posted. i found a couple of things that were quite interesting.
in Virtual Dyno 1.2.1 it shows the Evo 9 RS weight as 3219lbs. on Evoscan it showed the weight as 3020. Occ weight was 400 and that was entered in both programs.
VD had the log showing 460hp/375tq at smoothing 1
smoothing 2 was 448/372
smoothing 3 actually resembled the graph from evoscan
smoothing 4 was obviously smoother
smoothing 6
at this point i decided to enter the specs of evoscan into VD, so weight and tire height which was .07 higher was changed to mimic Evoscan
smoothing 1 showed 438/357
smoothing 2 showed 427/354
smoothing 3 which resembles evoscans graph
smoothing 4
smoothing 5 showed 420/349
and smoothing 6
i had a couple of people asking about running the log into VD after entering the same specs from evoscan, VD and Evoscan were really close. i was told that evoscan is using a smoothing of 3 so if thats the case than VD in smoothing 3 was 1hp and 1tq lower than evoscan. thats pretty close!
i plan on putting the car on a dynojet to cure my curiosity but i think i will be fairly close to what the programs are showing.
Old Mar 5, 2013 | 02:29 PM
  #34
Wow.....i think you should post a thread with this given information. So you can stop some of the ridiculous argument about evoscan reading higher than a dynojet lol or old virtual dyno. I think most of these arguments are pretty silly anyway as noone can give a true whp number that is 100% accurate.
Old Mar 5, 2013 | 07:37 PM
  #35
evo8426's Avatar
Evoscan log show different numbers on my computer, my eyes are not playing tricks on me
The argument is not ridiculous so no need in you whining about it since you yourself have no experience with it.
Old Mar 5, 2013 | 08:25 PM
  #36
tscompusa's Avatar
the new evoscan uses the same code virtual dyno uses, so they will read the same when using the same smoothing almost identical.
If you look at the about page with evoscan, it mentions Brads name in there since hes using the same code.
If you want to know whether or not your graph is inflated put it into virtual dyno with a smoothing of 0. if you have any high spikes its inflated. That graph looks fine to me.
If you don't have stock size tires don't post the graphs. use the proper tire size and leave it at that. 25.33 is stock tire height. 25.4 is 235/40/18 which will raise the dyno number vs stock tire height.
Old Mar 5, 2013 | 08:33 PM
  #37
WikdEvo's Avatar
you need to get your actual car weighed and enter your actual tire height to get accurate results from either program. Everyones car weighs differently. even an exhaust is going to change it by 20-30 lbs. Also. post a log with 0 smoothing and lets see how smooth the road actually is.
Old Mar 5, 2013 | 08:43 PM
  #38
tscompusa's Avatar
that is true. getting it weigh'ed is very important. only cost about $10 at a Cat Scale
I dont feel he needs to share smoothing 0. his graph looks fine to me.
Old Mar 5, 2013 | 08:50 PM
  #39
tscompusa's Avatar
On another note, here is the proof to backup what i said in regards to both VD and evoscan. they pretty much read very similar, but they are off alittle. it depends on how smooth the run is in general. If its really smooth, then there wont be to much difference from vd and evoscan. if you need to smooth it a lot, then there will be.
This example is of a bbk full i did a long time ago on 93oct on stock block. i figured if im going to show a comparison, do it with a car thats relevant to the thread. this car had way more mods, but you get the idea of the comparison between the evoscan and vd from another person.
car was a stock block evo 9 /w 8 trans, rev3 mani, s1 cams, jmf tubular, cbrd fmic, 93oct etc.
now i dont recommend running this much tq on a stock block, but the owner at the time wanted all or nothing.
Old Mar 5, 2013 | 09:01 PM
  #40
vmrevo9's Avatar
Veteran: Air Force
Thanks for the example Tom.
A couple of years ago I weighed my car an it was 3080 with the spare and jack removed if I remember correctly. But I haven't weighed it recently. Obviously weight of the car will change the power output on the programs. Hopefully I'll be putting the car on the dyno soon.
Old Mar 5, 2013 | 09:14 PM
  #41
tscompusa's Avatar
no problem at all.
I did a comparison with a customers car on a BBK full also vd vs dyno on ams dyno in the summer here and it was almost dead on. i think you'll have no surprises and you will be right in the ball park as it did in evoscan/vd.
3020lb is so light for stock! you are lucky to own an RS. mine is a pig even after removing half the interior its still 3040lb
Old Mar 5, 2013 | 09:54 PM
  #42
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by tscompusa
no problem at all.
Ive seen that thread before i like how close his numbers were.
If i were to guess My cars weight bi would put it at around 3100lbs. But i'll have to find a weigh station here to get an accurate number
Old Mar 6, 2013 | 03:00 AM
  #43
glad that's cleared up. Thanks Tom for the additional info.
Old Mar 6, 2013 | 03:08 AM
  #44
tscompusa's Avatar
ya you're probably almost dead on.
no problem at all.
Old Mar 6, 2013 | 05:22 AM
  #45
evo8426's Avatar
I am not using the absolute latest up to date version because it is buggy for me (cuts out during mid log, deselects items, re-arranges the order of items being logged, and shows different numbers in VD). I'm not making this stuff up.
A note on smoothness of the graphs from my experience is that logging too many items or using a slow computer will help hide rough roads. I'm sure another one of you is going to argue against me on that as well right?
I don't rely on evoscan and virtual dyno to make money, so I have no reason to support the programs and convince everyone that most of these graphs are legit. I'm not taking shots at any tuners but you can't tell me that you don't want everyone to believe the program is dead on.
Everyone needs to stop posting up a *single graph* and claiming they make that power. It is getting old seeing results without multiple runs and then not stating they are using virtual dyno in their signature as the numbers. There are so many fake results out there because of this program it is getting difficult to weed through it all. The graph originally posted looks pretty damn wavy to me.
NOTE: I am not discounting the tune on any of the cars.
