Mark's FPRed Powered Beast - 93 oct vs. 100 oct - Boostin Performance
This is Marks Daily Driven FP Red powered Evo 9. I built this Evo 9 for him years ago but it was time for some TLC, maintainance, and a freash tune.
Some things we replaced before the tune included: new TB shaft seals, new lower injector O-rings, we cleaned and flow tested his injectors, and installed a Hallman MBC and Grimmspeed EBCS to run hybrid boost. We also changed his trans fluild and engine oil.
On pump gas, boost was set to 26 psi, and on race gas boost was hitting 32-33 psi. The hybrid boost was nice up top on the race gas tune. Before hybrid boost, on a MBC with boost set to 33 psi, boost would fall off to 25 psi by redline. Using hybrid boost I was able to hold boost to 29-30 @ redline.
Mark has made a 10 second pass on Pump gas, and plans on taking it out on 100 oct some time soon
Some things we replaced before the tune included: new TB shaft seals, new lower injector O-rings, we cleaned and flow tested his injectors, and installed a Hallman MBC and Grimmspeed EBCS to run hybrid boost. We also changed his trans fluild and engine oil.On pump gas, boost was set to 26 psi, and on race gas boost was hitting 32-33 psi. The hybrid boost was nice up top on the race gas tune. Before hybrid boost, on a MBC with boost set to 33 psi, boost would fall off to 25 psi by redline. Using hybrid boost I was able to hold boost to 29-30 @ redline.
I believe the 100 octane was purchased from a Shell station, but I'd have to double check.
Boostin Perform
Nov 21, 2015 08:39 AM
Boostin Perform
Apr 30, 2014 10:08 AM
Boostin Perform
Evo X Dyno Results
32
Aug 25, 2013 02:42 PM
Boostin Perform
Mar 20, 2013 09:15 PM
