EVO9 20G vs 6262 Similar boost
Old Aug 12, 2013 | 08:33 PM
batty200's Avatar
Changes from 20G to 6262 are 2150CC injectors BR Double Pumper and a 6262 setup with HAFE cast manifold on SD.
My build thread is here: https://www.evolutionm.net/forums/al...read-junk.html
So I gave up some mid range and low down power but gained a lot up top same engine and everything just swapped turbo kit and fuel to supply bigger turbo. I will be able to crank it up more on the bigger turbo so the differences will be even more pronounced but there definitely is a give and take with everything. I will be tuning more to get better numbers. My goal is 600whp VD at 30psi. I think it is possible. The same road was used for both pulls but it is somewhat uphill so the numbers may be wrong but the comparison is still valid. I had a misfire around 4400rpm on the 20G graph so there is a little blip there. Weights were verified on a scale for each day. I had a ton of stuff in the car when I was doing pulls on the 20G.
Attached Thumbnails EVO9 20G vs 6262 Similar boost-20g-vs-6262-similar-boost.jpg
Old Aug 13, 2013 | 12:24 AM
FastGti69's Avatar
That's a nice chunk up top. Surprised your 20g spooled full at like 3.7k that's pretty fast!
batty200
13
Sep 1, 2012 02:08 PM
batty200
Jul 12, 2012 03:11 PM
batty200
For Sale - Cars For Sale
May 30, 2012 05:27 AM
FathouseFab
277
Aug 2, 2011 06:41 PM
k2boarder3187
Jul 5, 2009 09:07 PM
