good hp!!! bad MPH :(
I have HKS 4.11 Fd and Evo 8 3/4th gears. I dont have slicks though so I ran 18x9.5 and 265/35 street tires. Car made 740whp @38psi on ER dyno (~700-900ft MSL).At 33psi I ran a 10.6 @140mph with a 1.89 60ft at El Paso Motorplex (~3700ft MSL).
Though that combo he has might hurt his mph I dont think it would enough to make him trap under 140.
Something is not right. We both have 6466s
At 40psi/e85 I trapped 145mph and did 10.1 in a full weight SSL evo -- you also had a way better 60ft than me.
At 35psi/93 I trapped mid 130s and ran a 10.7
Regardless of the possibility of inflated dyno numbers, with that boost, e85 and that turbo you should be over 140mph easy. How much time was in-between the dyno/tune and going to the track? Do the logs look the same from the dyno and track or any variances?
I had Shep 5spd Ultimate Ratio with 4.11 and 265/35/18 tyres and it was hurting my traps... (2.3L with HTA82 at 6000ft above sea level)
went down to 235/40/17 Semi on stock rims and I picked up trap speed...
regards
Sal
You right onto money here, its the final gearing that must be holding it back...
regards
Sal
regards
Sal
idk know about this. With 4.11's on 245/45/r17 i went 10.65 @137 mph. On the stock FD and shifting into 5th i was doing 11.1@ 131-132 mph. The only think i changed was gears.
Maybe I missed this, but what kinda wheels and tires are you running and what suspension is on the car? You can make all the power in the world but if your not putting it down to the ground all that hp is useless.
4.11 is going to help you a ton though being your on a 2.4 wont help that much on 2.0 much.
1mbrews8
Nov 29, 2011 05:20 AM
JuniorAWD
Oct 4, 2010 06:30 PM
AWD Motorsports
Feb 18, 2010 02:17 PM
