Built Motor, 93oct DBB FP Black - Mustang dyno
Forgot to post my results a while back since finally completing the long build this car underwent. After many pistons, motors, mishaps(Not Dynotechs), it was finally tuned and back on the road this past May...
Below is my mod list and dyno sheet. I had run out of fuel, need bigger injectors/pump but the turbo didnt want to stop. Thanks to all that helped for this build and thank you Dynotech for everything as well
Will be upgrading to larger injectors and fuel pump, potentially E85 as well for next year.
426hp / 336tq
DBB FP Black
TurboSmart WG
Shearer Fab Manifold
MAP O2 Dump
MAP Rev2 Intake Manifold
Manley H-Beam rods
Manley Billet crank
Pistons: JE 85.5mm
ACL Main & Rod + Thrust
Main Studs: ARP
GSC Power-Division Valves
GSC Power-Division Single Beehive Valve Springs
GSC Power-Division S2 Camshafts for Evolution 4-8 VIII
ARP Cylinder Head Studs
STM Oil cooler
MAP Balance Shaft Elimination Kit
MAP Exhaust Manifold Stud and Nut Kit
Gates Timing Belt Tensioner Adjuster
Torque Solution Billet Aluminum Front Engine Mount
Torque Solution Billet Aluminum Passenger Side Engine Mount
Torque Solution Billet Aluminum Rear Engine Mount
Torque Solution Billet Aluminum Transmission mount
Weapon R Oil Catch Can
Mishimoto Race Radiator
AMS Sparkplug cover
AMS Intercooler w/ AMS LICP and UICP
HKS SSQ BOV (recirculated)
MAP Intake w/ Perrin Filter
Invidia 3" Downpipe
Perrin 3" Test Pipe
HKS Carbon Catback exhaust
HKS Cam Gears
Zaklee clear cam gear cover
Hallman Pro Boost Controller
Precision 850cc injectors
Perrin fuel rail
W255 Pump
Dyno chart is a little hard to read as it was in my glovebox a while..
the car
426hp / 336tq
DBB FP Black
TurboSmart WG
MAP O2 Dump
Manley H-Beam rods
Manley Billet crank
Pistons: JE 85.5mm
Main Studs: ARP
STM Oil cooler
AMS Sparkplug cover
Invidia 3" Downpipe
Perrin 3" Test Pipe
HKS Cam Gears
Perrin fuel rail
W255 Pump
the car
Love that car! See you in the summer for the dyno days, we love e85 down here so when your ready we are ;-) And the motor mishaps were not us so everyone knows! We built/assembled the final motor which is running strong :-)
-Brian
-Brian
Thanks
"Built motor, 93 oct DBB FP Black"
Yes
Mod list is in the original post, JE pistons, Full GSC top end, Manley Rods, Manley billet crank etc etc.
Thanks!
Yes
Thanks!
Pssst
13
Jun 26, 2014 09:07 AM
JBAutosports
Evo 'For Sale' Engine Internals and Drivetrain
28
Nov 18, 2012 05:03 PM
