Big turbos (6766/3794). Low boost numbers?
Just curious I have my 2.0 and 6766 combo set at 20 psi almost as a break in stage. I am awaiting fuel and better weather to turn the boost up where it should be. It makes me curious though if anybody had actually dyno'd their big turbos on the low boost setting. (Surely someone has)
62,64,6766, or a 3794 would probably be comparable. Looking for 20-25 psi numbers. It really is irrelevant but the car feels strong even on the pump fuel at that level with very conservative timing.
Again I don't want someone to tell me what my car is making. I want to know what others are doing.
Thank you
Thank you
Nice. That is similar. Probably much more torque than me but still comparable I would think.
I have not used the VD yet but it is not a bad idea. I will post a pull after work today.
Thank you
Thank you
