HELP!!! New build evo 8 2.4 cranks won’t start tried everything
#46
had to wait for my timing tools to come in the mail to make it easier on myself. I redid the timing and gave it a crank just to see if it would go possibly. I am getting no spark at all. Don’t know where to go from now?
#48
When you say holding spark plug to valve cover, I assume you are pressing the spark plug to a clean unpainted surface on valve cover. A picture of that would help too.
Personally, if I wanted to test like that, I would grab a wire and clamp it on a bolt on head (like the engine hook in front above cylinder #2 exhaust) and wrap the other end around spark plug thread.
Thinking about what you're doing some more, I don't think the valve cover is grounded to head. There are rubber separating it from the head and the cover bolts have insulators as washers. Try my wire method where you clamp wire to head (see blue circle below).
#50
Have you checked your fuses inside the cab? There's a fuse 7.5 amp for ignition that gets over powered when running aftermarket cop. I had the same issue with my new build. We had the battery tender on while priming the oil system and for its first ignition, and it kept blowing that ignition fuse. Bumped it up to a 10 amp and no issues with it still in there. It won't hurt anything putting a 10 in. It's gonna use more power with the cop anyways
#52
Car still has nothing
I’m still looking for some help as my car will not start from the shop. The technician says that it is the immobilizer that is stopping the car from starting. When I go to start the car I get spark and I get a one quick pulse for the injectors but no fuel. So I got around to taking out my after market alarm system thinking that might help but still nothing changed. At this point I’m thinking it’s a problem with the ecu and am going to take it to my nearest tuner 3 hours away. Does anyone have any thoughts on what it could be before I haul it 3 hours. Any thoughts help lots thanks.
#54
[QUOTE=2006EvoIXer;11852554]it should, theoretically.[/QUOTE
ok I’ll try to figure that out tomorrow and hopefully that makes it go. Would I have to do that every time to start it then though?
#58
The immobilizer is already off that’s why I can’t figure it out. So I removed my alarm system figuring that may have an immobilizer and still had nothing. Would a tuner be able to figure anything else out in the ecu that would cause it to not want to inject the fuel?
#59
#60
There's no point in having a tuner look at your car until we can determine that it is an ECU tuning issue.
It's possible an ecu is defective if CAS signal isn't triggering fuel pump relay #2 to activate. Anyway, fuel pump relays #1 & #2 are 2 of these 3 relays. I can't remember which two off the top of my head.
