EVO 8 FP RED Flex Fuel E70
Old Apr 9, 2018 | 05:03 PM
2006EvoIXer's Avatar
Originally Posted by ctfpevoVIII
yeah I’m a dummy guess I should of read his sig and like letsgetthisdone pointed out about his curve , it is definitely ss see how it hits later.
I only looked because you asked. I didn't see it originally either
It's a pricy setup when we can't use our O2 housing, downpipe, and internal WGA.
Old Apr 9, 2018 | 05:07 PM
Originally Posted by gqcode
Peak boost was 31 psi and went down to 28 and then going up. but my AFR 11.5 to 12 at WOT
why did it dip to 28 and then came back up to 30? Shouldn't it slowly drop to 30? It looks strange to me.
Old Apr 9, 2018 | 05:18 PM
gqcode's Avatar
Veteran: Air Force
That's on gasoline, and still a maybe depending on boost. When I first got my red, the walbro 255 was done at 26-27psi, 420whp.
On pump gas, the car went to 28 psi 400 whp. Fuel was not issued boost felt off after 6000 so I was thinking that i might have a boost leak. But on E85 no real issue but I will be working to locate if that car has a boost leak.
Old Apr 9, 2018 | 05:23 PM
gqcode's Avatar
Veteran: Air Force
BTW I did use my original downpipe. I had to modify the original gasket to make it fit in the FP housing! No exhaust leak but it was not easy. I used a grinder to make the doughnut slightly bigger
Old Apr 9, 2018 | 05:24 PM
What Sean meant is that 550 whp capability of 255 is on pump gas or C16. Because Ethanol gas requires up to 30% more flows for E85. So for E70, it needs about 24% more flow, reducing your 550 whp capability to 418whp, which is inline with what he got.
I think I miscalculated. I should have divided 550 by 1.24 and gotten 443whp. 550×0.76 is wrong.
Old Apr 9, 2018 | 05:28 PM
i applaud you for upgrading to this new SS setup. It's too much of a cost for me since I've already bought the O2 housing with ceramic coating, 3" Downpipe, and TurboSmart wastgate actuator.
Actually, that's pretty creative to plumb it back into O2 housing.
Old Apr 9, 2018 | 05:34 PM
gqcode's Avatar
Veteran: Air Force
I understand you need more ethanol about 30% more than gasoline. As you see I made 505 whp and the tuner didn't push it to the tune to edge. I ask the local around and a couple of them are still running a single Walbro making over 500 whp but none over 600 whp as you for need 450 or the double pump
Old Apr 9, 2018 | 05:40 PM
gqcode's Avatar
Veteran: Air Force
I was not happy at first because i didn't know about the SS! I call fp and if I knoew what know now I would send my 9 turbo to get the twin scroll. But TQ is the killer so I trade off the responsiveness for to top end! At first i didn't like it to much lag. I had bbk full prior to the red. But on E70 it's a different lag is minimal. Love the car
Old Apr 9, 2018 | 05:41 PM
Sorry double posted
Old Apr 9, 2018 | 05:42 PM
Wow, that's a lot for 255. How was your tuning session? Did you both ride in your car on a flat street to make this VD?
Old Apr 9, 2018 | 05:57 PM
gqcode's Avatar
Veteran: Air Force
yeah it was a long afternoon. He help fixing the Flex Fuel set up and a lot of driving. Yes we both were in the car and he explains everything he was doing. I just started to learn data logging so i understand some aspect of tunning. He educated me about my car, which was great
Old Apr 9, 2018 | 06:25 PM
Enjoy your beast, which has a new appetite for Lambos and Ferraris!
Old Apr 17, 2018 | 01:31 PM
sontoofly's Avatar
Made 505 whp/405tq
Wow! This is awesome, probably pulls super hard man! Have fun with it.
Old Apr 17, 2018 | 01:45 PM
badev0's Avatar
Torque curve looks pretty safe. Nice job!
Old Apr 17, 2018 | 07:29 PM
gqcode's Avatar
Veteran: Air Force
Yeah I love it! It hit hard at around 5000 all the way to red line. I'm happy with it, just trying now to improve the spool but amazing. Thanx to my tuner at AWHP.
