look for a base map for my evo 8
I am looking for some help for my 2.3 stroker evo 8. To make a long story short I have had if for ten years and I don't even have 200 miles on it because I bought some one else POS and I just had kids and a new house at the time. my family has always come first when it came to fixing the car. I just put a new 2.3 strocker in it and I need to put some miles on it before I get it dyno tuned. Iam going to RS mototsports here in Minnesota on the 17 of june. when I first go the car I went tp DP performance to get it tuned so that every thing was running good, That's when I found out that it had a lot of problems and rod knock so the tune was never finished so the car runs really bad now with the new motor. I have not gone for a drive in it for the fear of fing it up. I have always had a v8 rx7 that was my fun car when I found out that my wife at the time was having twins. I know I need a four door car for a fun car. So I sold the rx7 and got a 2003 GSR evo 8 that came with a lot of mod. but it turned out to have a lot of problems. So I took if home and its been in my garage ever since. Now that I got everything fixed. I tried to see if it would run and it does it just really bad.
So any help would be grateful.
Mod list
2.3 strocker
1000 cc injectors
255 walbro fuel pump
70mm throttle body
3.5 bar aem map sensor
GM speed density sensor
aftermarket intake manifold (modified stock manifold)
HKS 280 cams
3 inch intercooler piping
sparco front mount intercooler
Tial 50mm blow off vale
Tial 44 mm wastegate
GT35R turbo
Top mount exhaust manifold
3 inch exhaust for the down pipe all the way out back
Coil on plug with M&W ignitions PRO-12
AEM series 1 ECU
Mod list
2.3 strocker
1000 cc injectors
70mm throttle body
HKS 280 cams
GT35R turbo
AEM series 1 ECU
Dont take it to RS Motors for a tune if the car is already having issues, get those issues fixed before you take your car in. That's what they will tell you, and thats what any good tuner would tell you. First thing is to explain what your issues are, we know you still have issues, but is it a A/F ratio (tune) issue or is it really something else?
