2nd highest horsepower stock turbo?
So our tech Jake put together a 10:1 150mm rod 2.4 over the winter. We have about 220 miles on it so last night we took it to the dyno to see what it can do.
Mods- 2005 RS Stock IX turbo ER 2.4 GSC S2s FP Beehives JE 86.5mm 10:1 pistons Eagle rods Balance shaft delete Cometic HG FIC 1100cc high impedance injectors New 255 and fuel filter Minor bowl work on head, stock valves Ported exhaust manifold Ported intake manifold QTP O2 dump ER test pipe dump Stock throttle body Stock cat back Modified FP 18psi WG actuator Omnipower 4 bar ER Tune New sensor for both the WB and the MAP sensor So we started making pulls, got the timing and AFRs dialed and then put it to it. Here are the results- http://i275.photobucket.com/albums/j...ake470-470.jpg The next highest horsepower stock turbo car I found was Most Wanted who put down 468/492 ( https://www.evolutionm.net/forums/6592932-post561.html ). I didnt see a dyno graph so I cant compare the two but this thing is a beast. This is still straight WG line, since Jake wanted more miles on it before we really started spiking the boost. The FICs allowed me to run one pump, E98, and still be around 95% IDC on Evoscan. So there is really still some more in it even on this "big block". I'll get some screenshots of the logs in a bit. I know it isnt going to make much more power with more boost, but it will bring the torque up. You can tow with this thing now if you had to :) aaron |
great, but tell me you are going to a big turbo soon to support that 2.4? Looks like an STI stock turbo fall off after 5,500 rpm!
haha that's nuts, 470+awhp but falls to 350awhp, looks like the boost is holding steady to redline at that pressure. So I'm curious about your thoughts on what's causing the massive drop? hot turbo, dismal timing??
This will be getting a T67 in the near future. This was just to see what it would do and to test some ideas for some rally engines we want to do.
The reason it falls off is big motor little turbo with a lot of things to help it breathe. I actually played with timing and even went past MBT to see if it would come up out the top. That is all airflow (CFM) though and not timing. It doesnt make power past 17* at all, the blue line is actually at 19* but as you can see it didnt do anything. EGTs are actually low like you'd expect on an E85 car so I dont even think back pressure is a problem. Luke made 506 on his 2.0 10:1 with pretty much the same mods except for a lot higher spike (this has none right now) and an electric waterpump. His also had some crazy timing in it trying to get every last bit when it was it in that incarnation. The powerband isnt as bad as it looks when you break it down. 400 ft lbs from 3500-6000, 400whp from 4500-7000. |
gotcha, so next up is zinging the boost up higher to see if you can eek out a few more ponies across the board?
That looks like a nice road race setup Aaron. Is that why you stoped at 24 PSI? The TQ dips a little at 4k then comes back strong.
Originally Posted by Mellon Tuning
(Post 8003759)
Originally Posted by warp9
(Post 8003840)
Working on getting the logs up right now :) aaron |
http://img.photobucket.com/albums/v5...log470-470.png
Doesnt show in the log but this car will make 10psi at 1900. |
In talking with Jake, it sounds like this weekend at the dyno day he is going to start making this thing do work.
Wow, even to put a boost controller on this and see how early it'd make 25psi would be sweet, stump puller! :D
damn i had no idea that the stock turbo was this capable
What do those #'s look like corrected as thats how most wanted #'s were ran STD smoothing 3???
No disrespect but in your weather right now you must be on .97 correction at minimum.. We just made over 700 uncorrected on FP black but i didnt post about it since its 40 degrees here and we use standard STD like AMS and the rest.. btw.. Im not trying to start any trouble.. Just want to see your opinion.. thanks!! |
Pretty impressive!
Originally Posted by Mike@AwdMotorsports
(Post 8004849)
No disrespect but in your weather right now you must be on .97 correction at minimum.. We just made over 700 uncorrected on FP black but i didnt post about it since its 40 degrees here and we use standard STD like AMS and the rest.. btw.. Im not trying to start any trouble.. Just want to see your opinion.. thanks!! Of interest to some, we are also going to throw a 34mm restrictor on it to see what it would do in rally trim. aaron |
Originally Posted by JohnBradley
(Post 8005298)
Mike, I will doublecheck when I go to the dyno tonight. I believe set like that it was 467 corrected, but I am not sure on the smoothing. I will post that up as well as results from the weekend as we get them. Don't worry I knew you meant well and I didnt take it like it was anything else {thumbup}.
Of interest to some, we are also going to throw a 34mm restrictor on it to see what it would do in rally trim. aaron Mike |
