Virtual Dyno is available!
Hey everyone my friend and customer Brad Barnhill has been working on a standalone Virtual Dyno application. You can simply drag and drop your Evoscan log files into the program, tell it a few things about your EVO and viola! you've got a Dyno chart. You can even right click and copy or save the image file.
You can get the program here: http://www.mellontuning.com/index.ph...roducts_id=453 So go out and do a 3rd gear pull on flat ground and share your results with your mod list. I'll get us started: Mellon Tuning EVO 8 5-speed GSR on my 245/40/18 tires BR HTA86 @ 38psi on e85 700awhp. Buschur 2.0L Buschur Stage 3 head Buschur BF272 cams (Might go to Kelford 280/274 cams for better idle with ac) Buschur twin walbro fuel pumps Buschur 3" tbe, test pipe, bullet muffler Buschur 3" intake pipe + Mas adapter Buschur UICP and LICP Buschur Mini Battery Buschur Race FMIC Buschur COP Buschur Fuel Rail ARP head studs PPI ported stock intake manifold PPI 65MM throttle body FIC 1650cc injectors (going to FIC 2150cc high impedence injectors for better idle/cruise) Tilton Twin Disc Carbon clutch Tuned by Mellon www.mellontuning.com http://img.photobucket.com/albums/v4...alDynoRoom.jpg VS. MKC Dynojet http://img.photobucket.com/albums/v4...tionfactor.jpg |
Sweet!
That is some good stuff Mellon!
this works perfect. thanks for sharing mellon
Wow, that matches the Dynojet very close.
What vehicle weight are you using to get it to replicate dynojet numbers?
i cant wait to get dyno tuned and then try this and compare!
Originally Posted by Creamo3
(Post 8441898)
Can you do 4th gear? Ill spin 3rd...
yep
Thanks guys.... very cool.
Please remember, when posting graphs from virtual dynos, you must include the dyno type and dyno settings being used. Thanks
Originally Posted by MR Turco
(Post 8442476)
Originally Posted by Fast_Freddie
(Post 8442691)
Turco with this new program, the only thing you enter is car weight, gear and your weight...
personally i don't think anyone should be playing with that setting to keep the playing ground level. I wish brad would lock it down.
Originally Posted by Boosted Tuning
(Post 8442722)
Incorrect. There is setting for what dyno and dyno correction factor. Its in the "options", under "file".
