Boosted Tuning Remote Road Tune dyno'd on a Dynojet
2 Attachment(s)
Recently, a client I previously remotely road tuned went and dyno'd on a Dynojet. On to the mod list and dyno chart......
05 Evo 8 RS Evo 9 Turbo GSC S1 Cams Helix DP Custom 3" Exhaust with Test Pipe Ebay O2 Housing Perrin Intake Perrin MBC Perrin IC BR UICP AMS LICP Evo 9 DV "crushed" FORGE WGA Walbro 255 PTE 680 Injectors 94oct PUMP GAS Dyno conditions - 59*/ 35% humidity 25psi (is usually about 26-27 on the street, but only hit 25 on the dyno) 382hp/365tq UNCORRECTED The other dyno run was 373hp/359tq https://www.evolutionm.net/forums/at...1&d=1317776779 I found the last logs I had for this car (taken 7/14/11, temps were probably MUCH warmer) and ran them though VD. The chart is below. https://www.evolutionm.net/forums/at...1&d=1317776779 |
Nice seems most of the time the VD is really close on HP and under on TQ. Ill be hitting up a mustang dyno soon to see the diffrence should be intresting.
Nice job Jay.
Intersting to see the RPM shift in the peaks. It is to be expected due to smoothing but it's more signifigant then I thought it would be.
Nice, those numbers are really strong for pump gas. Better some guys e85 numbers. Good work my friend.
yeahhh buddy.
Damn, numbers are very close good job.
| All times are GMT -7. The time now is 06:11 PM. |
