I can't do a good dyno simulator
1 Attachment(s)
I don't know what I can be doing wrong here?
http://i196.photobucket.com/albums/a...ra/baddyno.jpg this is my log but I can not make the program work well. |
someone help me how to do a good dyno?
not too sure how to help you with that, but on a side note.. looks like a pretty good power band you have there!
I'm not the best at it, but it's pretty easy. Right before I'm about to do a pull, I start the logger since it takes a few seconds to begin. Switch to 3rd gear, at around 2800 rpms, hit full throttle until 6800ish. Make sure you're on a flat road. Stop,pull over and turn off log. I usually do 3 pulls each run. Open up file, the program does the rest as long as your profile is set up. If that's what you're doing, I don't have a clue, hopefully someone else will chime in. Are you sure you arent doing the pulls in second gear and spinning?
Delete it and download it again and see what happens , try using a different computer as well.
Force Fed jajaja very funny :crap:
1 Attachment(s)
Honestly, I lol'd....... sorry.
I threw your log into VD and came out with this. https://www.evolutionm.net/forums/at...0&d=1318730801 |
I have my SO in spanish, I tried in three diferent computer with Win7 in spanish and the same, the program shows the same issue. :rolleyes:
Originally Posted by AndyCT9W
(Post 9675228)
Your graph is showing in gigantic numbers, there's your problem.
This might be just me but it looks like your tire height and your gear ratios have a comma ( , ) instead of a period ( . ), maybe that has something to do with it?
Originally Posted by evo 9 guy
(Post 9675248)
If you have an evo ix with evo 8 gears what would you be choosing evo 8 or ix?
Originally Posted by Dragking2189
(Post 9675265)
Originally Posted by jonmorera
(Post 9675288)
The problem is only in my computer, others guys can runs my logs very well.
| All times are GMT -7. The time now is 06:52 AM. |
