I can't do a good dyno simulator
From: Costa Rica with business addres in Miami FL 33166
I don't know what I can be doing wrong here?
this is my log but I can not make the program work well.
I'm not the best at it, but it's pretty easy. Right before I'm about to do a pull, I start the logger since it takes a few seconds to begin. Switch to 3rd gear, at around 2800 rpms, hit full throttle until 6800ish. Make sure you're on a flat road. Stop,pull over and turn off log. I usually do 3 pulls each run. Open up file, the program does the rest as long as your profile is set up. If that's what you're doing, I don't have a clue, hopefully someone else will chime in. Are you sure you arent doing the pulls in second gear and spinning?
I have my SO in spanish, I tried in three diferent computer with Win7 in spanish and the same, the program shows the same issue.
