Stock block/head 8 ETS Bolt on's
All mod's are in Sig, This is @ 27psi 3rd gear 2500-7500 pull
http://i1139.photobucket.com/albums/...psacc70dfd.jpg |
what fuel were you tuned on?
Originally Posted by lostsoulsevo
(Post 10783559)
needs cams bad
Originally Posted by prowakeskater
(Post 10784215)
needs cams bad
Nice numbers. Do you have a baseline dyno?
Nice numbers for sure. You definitely cranked up the boost for those #'s. I'd feel uncomfortable DD'ing at 27 psi, even if it is on 93 oct...
Anyways great numbers :beer: A baseline would be cool. |
nice number with the set up you have
It only see's 27 for a few seconds, it tappers down to 22 pretty fast.
I did start noticing some surge so I'm probably going to drop it back down to 25 as I originally had. |
Originally Posted by kaonashi
(Post 10785671)
I did start noticing some surge so I'm probably going to drop it back down to 25 as I originally had. Would you mind posting the dynojet #'s overlaying the mustang #'s? Im just curious to see what you made on the dynojet vs the mustang. Id appreciate it :beer:. You're making more power than I do with HKS 272's @ 24psi (stock LICP ouch), on the same turbo. Im on 91 oct though. |
Looks good!{thumbup}
It's been a pleasure tuning this car. +1 on the cams and injectors. |
100k stock motor and going >.<
Originally Posted by BEKevo
(Post 10785693)
Nice, probably a good call. But regardless of that, you have a strong running car sir {thumbup} and kudos to Pure Drive (10isace) for the tune. Looks great.
(Post 10785785)
Not sure how to do a overlay with the 2 different dyno at once.
well the mustang dyno is 301/299 with a little better smoothing it also dropped the dyno jet to 347/339
| All times are GMT -7. The time now is 06:44 PM. |
