-   Evo Dyno Tuning / Results (https://www.evolutionm.net/forums/evo-dyno-tuning-results-299/)
-   -   IX Turbo's (budget building) (https://www.evolutionm.net/forums/evo-dyno-tuning-results/686723-ix-turbos-budget-building.html)
MnchMnchV84Lnch Mar 26, 2014 01:40 AM
Hi all what are some results when upgrading to a standard IX turbo (to any owners with the Series below IX). As I'm on a budget I want to upgrade from the stock VII turbo to the IX!!! Ive heard you can gain 30whp with co-operating mods
current engine mods:
Walbro fuel pump
Hot side and cold side IC piping
Trust front pipe and catback exhaust
1.2 bar actuator
tune on the evo 7 factory ecu with 210atwk @ 18psi
Not4Sale Mar 26, 2014 02:02 AM
It'll probably be cheaper, and better for now, to add bigger injectors, intercooler, and a set of drop in cams as opposed to the 9 turbo.
3K Mar 26, 2014 03:21 AM
How is this cheaper? You can get used 9 turbos for $250
egis Mar 26, 2014 05:53 AM
Either way,switching to 9 turbo is a smart move.i didn't find for $250,I bought full set up(exhaust mani,oil lines,etc) but it was worth it.around 30HP,maybe a little less.
Thoe99 Mar 26, 2014 07:15 AM
Here was my results back then:
https://www.evolutionm.net/forums/ev...ml#post8880853
I ended up upgrading turbos gain afterwards :)
boost556 Mar 26, 2014 07:32 AM
I agree get a FMIC atleast when upgrading to the 9 turbo since you will be running a little higher boost will avoid a lot of heat soak and will pick up more hp as well. I made 355whp with the 9 turbo, 255 wlabro licp, full cbe with meth @ 28 psi.
MnchMnchV84Lnch Mar 26, 2014 01:32 PM
Well here in AUS 9 turbos go for around 600-950 depending on milage. I was going for that turbo an o2 dump and a highflow cat. Hopefully I see close to a gain of 35whp
roach85 Mar 26, 2014 03:24 PM
I would buy a 9 turbo for cheap that needs rebuilt. Rebuild it with a 20g compressor wheel and SL2 turbine.
slowsrt4:( Mar 26, 2014 03:33 PM
I got my HTA71 CHRA for 600 bucks from FP, I made 360HP and 362TQ on a mustang dyno with the mods in my sig
MnchMnchV84Lnch Mar 26, 2014 04:10 PM
Those results Aren't not to bad @slosrt4. I can get a new 9 Turbo for 1000(AUD) through connections just Found out!!! :D So I think ill settle for that plus a 02dump and highflow cat at the same time ill do a timing belt and water pump (gates) if I can get 340whp im happy for 6 months
boost556 Mar 27, 2014 10:04 AM
don't use high flow cat get a resonated test pipe.
AWD_Launch Mar 27, 2014 11:24 AM
1000 for a Evo 9 turbo doesn't seem that great for such a small upgrade. I would go with a little bigger turbo like a green that won't add to much spool but really help with top end and overall power.
Ralliart004 Mar 27, 2014 02:09 PM
I have a 9 turbo on my 8 and managed to make 375 with supporting mods.
- FMIC
- hardpipe kit (intercooler and intake)
- greddy 720 fuel injectors
- turbo outlet
- HKS 280 cams
- COP setup (no real power difference)
- FP cast race manifold
- Full exhaust
Everything else is pretty much stock. The only change i have made since then was a FP anti surge cover and then switch to race gas or e85. Evo 9 turbos are cheap to find used and make decent power for most evo owners and pay for themselves in terms of keeping your car running overall.
MnchMnchV84Lnch Mar 28, 2014 01:25 AM
@ralliart004 do you feel your pushing the Bottom end with that power output?
Ralliart004 Mar 28, 2014 07:09 AM
To be honest I am much more comfortable with this output than trying to jump into a much bigger setup like 500+ or 600hp+. Most people through Evom and MLR have identified 400+ lb/ft to be the beginning of the end versus raw hp output.
I would love more power sure however the reliability and maintenance is going to be expensive.
