Evo 8 MR Full built 2.0 hx40 build
Hey guys,
I was hoping to get a rough idea of what I should expect my build to make in regards to power my car is a jdm evo 8 mr with a factory 6 speed, also if there is anything I should add to my build while it's still in its early stages, here is my mod lost below Wiseco Pistons Manley rods arp/2000 rod bolts Arp head studs ACL race bearings Cometic head gasket Kelford 272 5 angle valve job Tomei cam gears Gates timing belt kit ETS 3.5 inch intercooler Holset HX40 6 blade super with bep 0.60a/r Tial 38mm wastegate VTA 3 inch dump pipe Custom Steam pipe Manifold T3 single scroll Competion stage 4 cushioned 6 puck Full 3 inch exhaust 4 bar omni sensor 1150cc injectors Bosch 460 lph walboro fuel pump E85 Tephra v7 Should I be worried about my drivetrain as its stock. If so at what power level would it start being a issue, like I said if I can get a rough idea of what power this build is going to make that would be very helpful and also if there is anything you guys recommend to add while I'm here, thanks in advance !! |
will you be tuning it yourself?
Originally Posted by evo8tanner
(Post 11497436)
I can tell you in late october. Boostins tuning my car w/ stock block hx40 with bc 276s on 93/e85. I was hoping for 450 on e85
Originally Posted by boxerdropper
(Post 11498694)
No, the basic run down is: walbro 450 e85 pump& fic 2150s, bc 276s, 3.5" intercooler, ams 850r turbo kit with a 6 blade hx40/ .63 ar exhaust housing. buschur short route piping.3" catless exhaust. Just trying to make a nice street machine that can bang out some 11 second passes, and spool before 5k.......hopefully haha
(Post 11499255)
I will post a thread. What kind of numbers or 1/4 did he get out of it. If you don't mind me asking
(Post 11499644)
