Full built 2.0 hx40 build
Old Aug 24, 2015 | 04:39 AM
Squid747's Avatar
Evo 8 MR Full built 2.0 hx40 build
Hey guys,
I was hoping to get a rough idea of what I should expect my build to make in regards to power my car is a jdm evo 8 mr with a factory 6 speed, also if there is anything I should add to my build while it's still in its early stages, here is my mod lost below
Wiseco Pistons
Manley rods arp/2000 rod bolts
Arp head studs
ACL race bearings
Cometic head gasket
Kelford 272
5 angle valve job
Tomei cam gears
Gates timing belt kit
ETS 3.5 inch intercooler
Holset HX40 6 blade super with bep 0.60a/r
Tial 38mm wastegate VTA
3 inch dump pipe
Custom Steam pipe Manifold
T3 single scroll
Competion stage 4 cushioned 6 puck
Full 3 inch exhaust
4 bar omni sensor
1150cc injectors Bosch
460 lph walboro fuel pump
E85
Tephra v7
Should I be worried about my drivetrain as its stock. If so at what power level would it start being a issue, like I said if I can get a rough idea of what power this build is going to make that would be very helpful and also if there is anything you guys recommend to add while I'm here, thanks in advance !!
Old Aug 24, 2015 | 05:30 PM
evo8tanner's Avatar
will you be tuning it yourself?
Old Aug 25, 2015 | 04:01 AM
Squid747's Avatar
I'm not tuning it myself my tuner is
Old Aug 27, 2015 | 07:33 AM
boxerdropper's Avatar
I can tell you in late october. Boostins tuning my car w/ stock block hx40 with bc 276s on 93/e85. I was hoping for 450 on e85
Old Aug 28, 2015 | 01:26 AM
Squid747's Avatar
Sounds good man, are you sticking with the stock intercooler ?
Old Aug 28, 2015 | 09:13 AM
No, the basic run down is: walbro 450 e85 pump& fic 2150s, bc 276s, 3.5" intercooler, ams 850r turbo kit with a 6 blade hx40/ .63 ar exhaust housing. buschur short route piping.3" catless exhaust. Just trying to make a nice street machine that can bang out some 11 second passes, and spool before 5k.......hopefully haha
Old Aug 29, 2015 | 06:00 AM
Squid747's Avatar
One of my friends had a similar setup to you and his setup spooled just under 4500 with a stock cooler and stock cams, you should be fine! Let me know how you go anyways when it's done
Old Aug 29, 2015 | 07:04 AM
I will post a thread. What kind of numbers or 1/4 did he get out of it. If you don't mind me asking
Old Aug 29, 2015 | 06:08 PM
Squid747's Avatar
He never tracked it which was a shame
Old Aug 29, 2015 | 10:17 PM
deylag's Avatar
This guy maxed out an hx40.
https://www.evolutionm.net/forums/ev...-144-36-a.html
fast03evo
Aug 17, 2014 06:09 PM
talonkev
Sep 25, 2013 09:01 AM
JDM EVO 6
Dec 2, 2012 03:35 PM
blaze165
22
Jul 19, 2012 11:04 AM
