-   Evo Dyno Tuning / Results (https://www.evolutionm.net/forums/evo-dyno-tuning-results-299/)
-   -   EVO 8 CBRE 2.0 6466 1450's E70 37PSI (https://www.evolutionm.net/forums/evo-dyno-tuning-results/733028-evo-8-cbre-2-0-6466-1450s-e70-37psi.html)
STLEVOIX Sep 15, 2016 10:53 AM
Car started here with stock turbo then swapped to a MHI FP RED JB
https://www.evolutionm.net/forums/ev...turbo-e70.html
Car is still on factory fuel lines and factory regulator. FIC 1450's are at 99% duty cycle maxed out. Fuel is E74-E75 pump. 37PSI @ 11.5
CBRE 2.0 9.5:1
CBRE Head
CBRE Intake Manifold
GSC S2 cams
PTE V-band 6466 .82
Fic 1450's
Double pumper
Grimmspeed 3 port
Shep tcase/trans
Stock ECU w/ Tephra
Best car went was 11.7 @ 132 w/ a 2.1 60 foot
https://cimg9.ibsrv.net/gimg/www.evo...8edaf9b43f.jpg
EvilTechnology Sep 17, 2016 04:29 PM
Very nice! Hows it feel?
STLEVOIX Sep 17, 2016 07:50 PM
Car feels great! Definitely laggier then my old fp red setup, but hits harder and pulls harder. Happy i made the switch
STLEVOIX Sep 17, 2016 07:52 PM
1 Attachment(s)
Did test and tune today at Street car take over here in STL. Was fun, but I could not compete with the GTR's
Attachment 254337
STLEVOIX Sep 17, 2016 07:53 PM
1 Attachment(s)
Originally Posted by STLEVOIX (Post 11663981)
Car started here with stock turbo then swapped to a MHI FP RED JB https://www.evolutionm.net/forums/ev...turbo-e70.html Car is still on factory fuel lines and factory regulator. FIC 1450's are at 99% duty cycle maxed out. Fuel is E74-E75 pump. 37PSI @ 11.5 CBRE 2.0 9.5:1 CBRE Head CBRE Intake Manifold GSC S2 cams PTE V-band 6466 .82 Fic 1450's Double pumper Grimmspeed 3 port Shep tcase/trans Stock ECU w/ Tephra Best car went was 11.7 @ 132 w/ a 2.1 60 foot
Updated numbers, back to back 3rd gear pulls. You can see it starting to go lean. Injectors maxed out for sure.
Attachment 254338
STLEVOIX Oct 5, 2016 12:32 PM
Small update. FIC 2150's waiting to be installed, along with a -8 fuel feed line. I am building a new double pumper with AN fittings as well. Going with brand new pumps. A 255 as primary and a 450 as the secondary activated by the hobbs switch. Not going to be doing a rewire. Also have a Fuel Lab AFPR that will be installed. I pulled the transfer case and sent it out to Jack's to be rebuilt to handle the increasing power level as well.
EvilTechnology Oct 6, 2016 10:50 AM
Awesome!! Nice to hear{thumbup}
Teal2nnr Oct 6, 2016 05:49 PM
I thought the MPH would have been higher with that amount of power. I guess we'll see what it can do with the fuel upgrade.
STLEVOIX Oct 7, 2016 09:10 AM
I have stock final overdrive. If i had a 4.11 in sure the mph would be higher
Migsubishi Oct 8, 2016 05:10 AM
Your going to keep the ix transmission right, just add a 4.11?
STLEVOIX Oct 10, 2016 08:31 AM
4:11 is going to happen, but not for a while. My transmission now has 0 issues and shifts like butter, so I am not going to touch it for the time being. The transfer case arrived at Jacks on Friday. I am opting for the Stage 3 Indestructible, which has a bout a month turn around time.
Teal2nnr Oct 10, 2016 11:27 AM
A 26" QTP should help your MPH a lot.
