Evo 9 RS Stock turbo, stock cams, E-85 at RRE
Got tuned today by Sam at RRE! Didn't expect these numbers and the car pulls like crazy compared to 91 haha. If you're in the SoCal area I'd definitely recommend Sam at RRE for all your tuning needs .
https://cimg9.ibsrv.net/gimg/www.evo...1c56194e5b.png |
Mods:
TBE (no cat) Intake Upper and lower IC piping Spoolinup COP Synapse DV Walbro 255 ID 1050x injectors Grimmspeed 3 port @ 27 psi |
Nice! So little mods too!
Stock EBC?
Well Done. The first experience w/E85 is always a good time.
Welcome to the So.Cal E85 / Sam tuned group :beer: |
Nice results! Could you post boost and afr curve? |
Great results, {thumbup} |
Nothing like picking up ~ 90 WHP and 90 lb/ft of torque. The stock turbo is a riot on E-85.....enjoy
@ 2006EvoIXer Grimmspeed 3 port boost controller
@ whtrice Yea the increase in torque is a lot of fun; hits hard and early. I was pleasantly surprised the first time I did a pull. @ MinusPrevious Sam is super knowledgeable as both a mechanic and a tuner. Very good combo. |
stock long block?
@Big_Mike1 stock head and ~ 4000 miles on a new OEM short block
Fun times!
Here's the boost and AFR curves. Just a note, the Dyno wideband reads about 1.0AFR lean, So 12.5 is actually 11.5 and 11.5 is actually 10.5 or so. Sam said my AEM wideband read correctly, however, the Dyno wideband did not.
The AFR readimg is taken from sensor in tail pipe. I think that tends to read leaner than it really is at engine.
