Will a Full stereo system install run on Mini Battery?
Old Sep 12, 2006 | 11:58 PM
Lagsux's Avatar
Wondering if anyone is running a full stereo system (ie. amps, subs, separates, etc.) with the mini battery kit? If so, is there a need for ungraded alternators or is the stock one good to go?
Thanks!
Old Sep 12, 2006 | 11:59 PM
EVO8 WHOA's Avatar
no... i did a mini front and another mini with an isolator in the trunk..
Old Sep 13, 2006 | 12:05 AM
Lagsux's Avatar
Will the stock alt. keep both batteries juiced up? Or did you have to upgrade?
Old Sep 13, 2006 | 12:19 AM
Rcebowl's Avatar
what size amp what size sub ... these all make a difference ...
i'm currently running Kicker KX 6.5 in the front and a L7 8" solobaric, with a Alpine MRV-F 345... with NO issues at all... my lights dont even dim when the sub is turned all the way up...
but that's ONLY bc i'm using since a small amp =/
Old Sep 13, 2006 | 12:29 AM
Lagsux's Avatar
Gonna be running a few old ones... OG Xtant 1001 and 2 RF Power Series Chrome 50.2s. On top of this, I've also got some old school active x-overs and stuff.... Pulled it all out of my old supra awhile back and thinking to throw it all into the Evo.
Old Sep 13, 2006 | 12:49 AM
Rcebowl's Avatar
oo ****! u still have one of the Xtant 1001's?!?!? those *****s were/are badddd those are gonna pull soommme power... your stock alt should be ok if you run two bats or maybe a GOOD mini bat
Which mini bat do you have? i cant remember who.. StatX or Stinger or who ... but their's a mini Bat that outputs just as much a normal size bat
ill post again tomorrow on who it was when i ask my friend
Old Sep 13, 2006 | 05:55 AM
FJF's Avatar
FJF
I just have to ask. Why save weight with a mini battery and add countless pounds of audio gear?
Old Sep 13, 2006 | 09:44 AM
MREvOTard's Avatar
mini batterys are not good if ur gonna sit there and listen to music. if u want something thats decently light and good *** power use a D51 yellowtop optima best bang for buck.
Old Sep 13, 2006 | 09:57 AM
Rcebowl's Avatar
not everyone using a mini bat to lose weight .... most people do it to so they can run shorter intercooler piping
Old Sep 13, 2006 | 10:44 AM
MREvOTard's Avatar
yeha pretty much, i have a d51 in my evo, it works good just make sure its a yellow top optima.
Old Sep 13, 2006 | 10:45 AM
Lagsux's Avatar
Thx Rcebowl , that's exactly why. I'm getting the genysys mini battery so the UICP & the Oil catch can will fit in the engine bay.
Old Sep 13, 2006 | 10:48 AM
Lagsux's Avatar
Prolly not gonna fit. Btw, when I had the system in my Supdawg, the juices had to be recharged every once in awhile due to the alternator. You guys sure the Evo Alt is better than the stock Toyota?
Thx again!
Old Sep 13, 2006 | 10:51 AM
Jasil's Avatar
Why? They have pipes that fit around the stock battery and the difference is negligible.
DontRevMe's Avatar
The alternator is far more important than the battery. But if you're worried, Relocate with an optima yellow top into the trunk area. This will add engine room without hurting amerage. I would advise upgrading all of your factory grounds and charging system cables to atleast a 4agu.
Old Sep 13, 2006 | 11:02 AM
FJF's Avatar
FJF
[...text edited......]
