Installing gauge kit on GSR
Old Nov 3, 2006 | 07:45 PM
mike127's Avatar
Question Installing gauge kit on GSR
Anyone know if there is a kit for installing the factory gauge kit in the lower opening on a GSR ( in place of the "change" tray)? It doesn't seem to have the bracket necesary to mount the four screws to.
Mike
Old Nov 9, 2006 | 07:58 PM
evo72man's Avatar
If you unscrew it, I believe there is four screw holes. Thats where I installed my gauges.
Old Nov 26, 2006 | 05:18 PM
mike127's Avatar
Smile
Bringing this one back from the dead! If I place the OE sports meter gauge kit in the lower opening on a GSR (where the change tray is), I assume i would then need the black plastic housing that surrounds the gauge kit on an MR and RS. Does anyone know the part number on this piece, as the radio relocation piece only works for a radio, not the OE gauge pack. Thanks. I'll post this in part number requests, also.
Mike
Old Nov 30, 2006 | 04:36 PM
evo72man's Avatar
I think it would be easier if you mount the OEM gauge set in the spot where the factory radio is. It bolts right in. Then if you have an after market radio put the can where the radio slides into the bottom portion of where the change holder is using a relocation kit. That is what I did. But if you want to you can also bolt the factory radio into the relocation kit. The kit is like $50, you will need the kit either way.
Old Nov 30, 2006 | 04:49 PM
mike127's Avatar
Smile
Thanks for the info! I have the radio relo kit but I would like to put the gauges on the bottom. There seems to be a large space between the mounted gauges and the black plastic trim piece. Are the gauges in the MR and RS's mounted directly to the trim piece or are they mounted differently so they sit flush behind the trim piece? Anybody with an MR or Rs that has relocated the gauges to the top can probably answer this one, hopefully!
Mike
Old Jul 24, 2007 | 08:33 PM
KOM88's Avatar
they are mounted like a normal gauge.... there is a nut on the back that holds a retaing clip to the (also on back) panel. so in other words, they are flush mounted, and you can easily move them around from spot to spot.
MR_mike
Feb 11, 2014 07:02 PM
skatermsmn
For Sale - Part Outs
14
Jan 29, 2014 11:55 AM
rastamike
Southeast Region
24
Jul 18, 2013 12:29 PM
SaiKyo
Jul 22, 2011 06:08 PM
