need expert advice please
Old Mar 1, 2007 | 07:23 PM
Rexpeed's Avatar
I am going with one Alpine 12inch Type R woofer for my Evo trunk. Which Alpine amp should I get to run the woofers. kinda on a budget so no need to get the top of the line model. I only want to stick with Alpine only.
Should I go for 2 or 4 ohm for the woofer and which model number for the amp?
Thanks
http://www.woofersetc.com/index.cfm?...category_id=23
http://www.woofersetc.com/index.cfm?...&category_id=3
Old Mar 1, 2007 | 07:31 PM
Curt@MrLed's Avatar
Former Vendor
i had 2 type r's d/v 2 ohm with a concept 1200 amp.. it sounded good, they are good speakers for the money, but after 2 years the surrounds seperated.. so i stepped up to treo d/v 2 ohm, 5 times better sub, and come with a 3 year warrenty.. they are a little more expensive, not much but worth every dollar.. again type r's are good, but for the money go treo.. my 2 12's and the concept amp, which is 1/4 ohm staple class d has been going for 4 years.. just my advice hope i helped..
Old Mar 1, 2007 | 07:40 PM
Rexpeed's Avatar
thanks! either that or I might just get the ID MAX 12 inch woofer.. dont want to weight the car down
Old Mar 1, 2007 | 07:44 PM
theretardtim's Avatar
The IDMAX is a serious sub, its massive and you'll need an equally impressive enclosure to match it. I recommend looking into Image Dynamics IDQ line, one of my favorites. It will also help out with your budget since its cheaper then a Type R and requires less power to move it which translates into a cheaper amp.
Old Mar 1, 2007 | 07:50 PM
evosr2bnvd's Avatar
i want a system like that. i have nothing. where do i start. hahahah
Old Mar 1, 2007 | 07:54 PM
Rexpeed's Avatar
I got this from a guy i know who used to install high end stereos.
"get the IDMax 12 in dual 4 ohm and wire the voice coils in parallel. That will get you 2 ohms total impedence and that amp will give you 600w.. get the Alpine MRP-M650" of course this isnt the best but its something he says will work good.
Does this make sense?
Old Mar 2, 2007 | 08:11 AM
Curt@MrLed's Avatar
Former Vendor
oh and the alpine sub needs 1 cubic foot for space in a solid box, treo needs .75.. with these subs and a trunk bar and a 5 gallon air tank i still have half my trunk..
Old Mar 2, 2007 | 12:41 PM
M00kiE's Avatar
If you're staying with one sub, I'd go with a 4ohm model if they come in dual voice coil (DVC) if its a single voice coil, I'd go with the 2 ohm version.
Old Mar 2, 2007 | 05:01 PM
Yup he knows what he's talking about but the IDMAX 12 takes 1,000w RMS for optimum performance. You'll still be very pleased with its performance and SQ with that amp. Good luck!
Old Mar 2, 2007 | 05:13 PM
evo4g63awd's Avatar
go for the mrd m605 for one 12" type r, 2 ohm, thats what i have in my evo. check it outhttps://www.evolutionm.net/forums/sh...d.php?t=226721
Old Mar 2, 2007 | 05:52 PM
Rexpeed's Avatar
^^^nice install. is the woofer suppose to face the back of the trunk to get maximum bass?
Old Mar 2, 2007 | 05:56 PM
evo4g63awd's Avatar
thank you . yes
Old Mar 2, 2007 | 05:59 PM
Rexpeed's Avatar
in the middle? I thought you could make it sit in a a corner or something like that.
Old Mar 4, 2007 | 08:02 AM
BillAce's Avatar
You should have at least 700 watts to an ID Max sub. At that power level you will be able to reach full excursion and any more power will have minimal effect on volume but create a great deal of heat. This is unless you are going for one note SPL, then the extra power will be able to push past the mechanical limits of hte sub. This of course will damage the sub over time.
As far as amps go, unless you have to use Alpine for some sponsorship or other reason, I would look into something purpose built. Alpine, Pioneer, Eclipse, Sony etc. don't build amps for the best possible poerformance. They have price points and cosmetics as the primary concerns and follow that up with a rediculous power claim to sell product. THere are many companies that employ their own team of engineers to design amplifiers only and the performance of the product is the focus. I compare this to buying APC or Buschur parts, one is cheap in a pretty package and the other really works...
Old Mar 4, 2007 | 10:30 AM
Rexpeed's Avatar
i already bought the alpine amp and id max i know it wont be the best but im sure it till sound decent. thanks for all the help
