Are the sensors from OEM gauages compatible with DEFI or other guages?
I have OEM gauages which came with IX MR. I would like to move it up to radio location but also would like to use aftermarket gauages along with Gruppe-s gauage holders.
I am initially trying to use the stock sensors and change the gauges only as I plan to add EGT later on.
I've searched forum but I am finding only how to on swaping the radio with gauages.
Can anyone tell me if stock sensors are compatible with aftermarket gauages?
Thanks,
Dan.
Thanks,
Dan.
depends on the gauge, a boost gauge normally runs the same as the stock gauges ( vacume line on back, illumination and a ground) the oil temp may be compatible with others but i deffinetly don't know about that for sure, i noticed that when i put an aftermarket deck in my evo the voltage gauge stopped being so accurate, the oil temp sensor that comes out of the pan, follow that line with your hand for about two feet and then theres a clip, un clip and see if you can find a gauge that has that specific fitting.
