HELP.. wing on CF trunk..
Old Jun 4, 2007 | 01:39 PM
CadiLuva's Avatar
wussup fellas.. i have a CF trunk and CF wing.. i am scared to tighten the screw too tight and crack the CF.. but at the same time i recently noticed my some of the screws on the wing had become loose.. i also notice the wing moves a little bit.. what can i do to make my CF trunk stronger or more rigid??..
i know this is outta my non-evo lancer world.. but i figured you guys would have some more experience with this sort of thing.. thanks..
Old Jun 5, 2007 | 02:28 PM
Sky3's Avatar
Why not just drill it? Its being clipped on now?
Old Jun 5, 2007 | 07:53 PM
Noe18's Avatar
where did u get the cf trunk and how much
Old Jun 5, 2007 | 09:03 PM
sly's Avatar
sly
how is it bolted on right now ?
Old Jun 5, 2007 | 09:46 PM
CadiLuva's Avatar
its a VIS trunk.. also the wing is bolted on.. im just gunna loctite the bolts.. i took it up to about 120 MPH and it did better than at 60-70 MPH.. i need some bars for the inside of the trunk that would attach to the wing bolts and increase the rigidity..
al i can say is forget about having your rear end all over the place..
Old Jun 7, 2007 | 04:05 AM
CadiLuva's Avatar
what are those latched on the trunk??..
Old Jul 28, 2007 | 12:55 PM
KenMasters's Avatar
Those are simillar to hood pins. I think they can pull the whole assembly off. The trunk is not hinged on that car. It probably has pins on the top as well.
Old Jul 28, 2007 | 01:52 PM
evo_tiago's Avatar
CAdiluva----what kind of spoiler do you have. i like ure plates..
Old Jul 28, 2007 | 05:58 PM
RallyDave's Avatar
No, the trunk is still hinged it doesn't have a latch or locking mechanism. All or nearly all racing sanctioning bodies require hood and trunk latches to be disabled. They are springs to keep the trunk down.
Old Jul 28, 2007 | 06:27 PM
KenMasters's Avatar
Ok, then.
What he said.
Old Jul 31, 2007 | 12:01 PM
pkang's Avatar
nice car
Old Sep 2, 2007 | 10:14 AM
S2myEvo's Avatar
not bad...i like how your lancer looks.
Old Sep 6, 2007 | 06:04 PM
06ebgsr's Avatar
wingless with the CF trunk just looks so mean unless ur planning on taking it to the time attack.... good pics though
