XM Radio installation
Old Jun 11, 2007 | 04:47 PM
c_sautter's Avatar
I have an XM Sportscaster and I'm having a little trouble on figuring out where to put everything. It doesn't look like any of the wires will be flush anywhere, you will definitely see it. Has anyone installed their own? I'm thinking of having it done professionally and I think that would be best before I messed it up. Anyone have any suggestions?
Old Jun 12, 2007 | 04:30 AM
LayinLo's Avatar
I mounted up my Sirius with no problems.
Just have to think out where you wanna put it, then see if the wires can be hidden behind the dash or A-Pillars, etc.
Where do you wanna mount it?
Old Jun 12, 2007 | 12:01 PM
c_sautter's Avatar
I want to mount it to the windshield above the dash, centered in the middle. I guess the problem I'm having is figuring out how to hide the wires without tearing into the car too much. I don't think I'd be able to fix it if I f***ed it up.
Old Jun 12, 2007 | 12:19 PM
CasperGSR99's Avatar
push it with a plastic bunch down under the plastic where the dash and windshield meet... thats what i did for my navi antenna... no removal of anything necessary. you can wire it across the windshield then down around under the dash
Old Jun 12, 2007 | 01:06 PM
c_sautter's Avatar
What about the magnetic antenna? Since the roof is aluminum, the magnet doesn't stick. How did you do it with that? I kept walking around the car, trying to find a good way to run the wires, but I don't want it to show too much. I think I might have to anyway. And the manual for the radio says to have the antenna 6 inches from the door. I think I can put it on the trunk lid.
Old Jun 12, 2007 | 08:09 PM
Fujilicious's Avatar
I'll be installling my XM tomorrow-- I planned on centering the antenna on the trunk lid as well. I think reception will be fine, plus I can easily tuck it inside the trunk for security reasons if necessary.
Old Jun 13, 2007 | 02:51 AM
s2kguy's Avatar
My xm antena thing is on the dash up near the front window in the center. I've had XM since it first came out on 3 cars now, I've never once had an issue with it there.
No need to mount it outside the car.
Old Jun 13, 2007 | 08:56 AM
NoTec's Avatar
It is recommended to mount the antenna outside the car but as S2Kguy has pointed out, mounting it inside the car probably wont cause any issues unless the windshield has a special element in it. It should be fine on the dash towards the windshield. Some guys have mounted both nav and sat. radio antennas on the rear deck but under the carpet covering.. Sometimes it works out well but in some cases, the defroster causes issues with the signal. Good Luck.
Old Jun 13, 2007 | 11:38 AM
c_sautter's Avatar
Wow I didn't even think about just putting the antenna on the dash too. Sounds like a good idea. And I was going to pay someone to do this.
Old Jun 13, 2007 | 11:45 AM
Evoryder's Avatar
my antenna is inside the car...i have the 'roady2' radio
you can see the antenna right where the dash meets the windshield
Old Jun 13, 2007 | 01:20 PM
c_sautter's Avatar
Oh yeah, that doesn't look bad at all. Thanks evoryder
Old Jun 17, 2007 | 03:10 PM
buddha1320's Avatar
heres mine b4 i got a new unit antenna is on the upper part of passenger side dash and since i have the apr mirrors no need for mirror switch
Old Jun 17, 2007 | 03:12 PM
XtoEvolution's Avatar
My antenna came with a magnetic pad and I stuck it on top of my 3rd brake light with my GPS antenna. Works perfect.
Old Jun 18, 2007 | 12:01 AM
c_sautter's Avatar
Sticking it on top of the third brake light doesn't seem like a bad idea. I think I'm going to have to accept the fact that some wires will show, which is what I don't want. Oh well
Old Jun 18, 2007 | 03:28 AM
NWEvoViii's Avatar
buddha1320, Looks like you work in the Circuit City Road Shop.
