HID Conversion For IX?
Old Jul 11, 2007 | 08:41 AM
beemerfreak's Avatar
I found a 03 Evo with HID housing and bulbs. Can I buy it and install it on my car?
Its from a car thats been in a accident. What would I need to have a complete install.
Old Jul 11, 2007 | 08:51 AM
bump
Old Jul 22, 2007 | 08:33 AM
zli05's Avatar
I think you can swap the headlight. You will need to make sure the headlight that you are buying has ballast and HID bulbs. If it only have the HID bulbs then you will need to get 2 ballasts to make the HID work. You will need 2 wires to connect your low beam plug (9006) to the ballast for the low beam to work. For high beam, your high beam plug (9005) should pulg right in without a problem. For the fog light, if you want to make it like stock, you will need to get the OEM fog light wire harness and the fog light switch button (ask the guy who selling the headling, you may able to get it from him).
