Alternate wiring, dash and steering removal - oh my?
Old Sep 26, 2007 | 10:59 PM
EvoIXMR's Avatar
Doing a bunch of stuff and need help and advice from advanced users...
1) Tap into power window and door lock switches?
Since the Evo is getting stripped including doors, I would like to tap into power windows and locks and eliminate the switch panels on the doors. Anyone know where these wires are under the dash?
2) I may need to remove the dash, so I have 2 questions:
- Can I remove the top panel separately or is it one whole piece? If I remove top panel, I would have access to the main wiring harness easier, or so it seems.
- I am also removing the SSL amp harness and have it separated upto the dash where it goes up into it, I need to get to this as well and was wondering if it plugged in somewhere else - anyone know?
3) Do I need to remove steering wheel to remove the dash from the car?
4) How does the passengers side airbag unplug, I assume I need to do that to take the top dash out?
Thanks!
PS - I am waiting for my manual CD to come in which should help a lot, I hope!
Thanks!
Old Oct 1, 2007 | 05:50 PM
justchil's Avatar
I'm trying to figure out how to get this dash out... have you gotten anywhere with this? I can't seem to find it in the manual but I've taken a lot of stuff out. It seems to be stuck on the top portion near the center closest to the firewall.
Old Oct 1, 2007 | 05:56 PM
justchil's Avatar
No you don't have to remove the steering wheel.
Here you go: http://justchil.net/dl/evo/dash.pdf
Old Oct 1, 2007 | 06:43 PM
EvoIXMR's Avatar
justchil - We meet again!
Yeah, dash is out. Thats how I took all the sound deadeing off firewall. Had to remove the blower and heater core - yuck!
The PDF doesnt show 2 bolts that hold the airbag bracket - one is behind ECU and has to be reached with a swivel, other should be easily accessible.
The pass airbag sorta lifts up straight off with the dash and then come forward.
Hope this helps!
Old Oct 1, 2007 | 06:44 PM
EvoIXMR's Avatar
So, taking AC out, can I still have heat? Defroster may not work as well, I figure!
